Subject: Newbie question on eyebrows,etc
stargsr opened this issue on Nov 23, 2007 · 4 posts
stargsr posted Fri, 23 November 2007 at 6:06 PM
Can some tell how to add the brows and lashes to V3 in Poser?
Thanks in advance.
SSAfam1 posted Fri, 23 November 2007 at 6:12 PM
1)How new are you? Do you need diagrams or are you familiar with the basics(especially MATERIAL ROOM) so that words alone would suffice?
2)Do you have eyebrows painted on the head texture?
SSAfam1 posted Fri, 23 November 2007 at 6:27 PM
If you DON'T have eyebrows painted onto the head texture:
Go to the Materials Room. (Advanced tab) Go to Transparency node, right click then attach a new node. 2Dimage map. Click on the NONE at the top of the newly attached node. Browse to where your eyebrow texture is. Select it. Set Transparency and Transparency Edge to 1.0. Set Transparency Falloff to 0 along with Spectacular value. Do the same for the eyelashes.
Render settings to get the best lashes:
In Poser 6, set the max texture size render setting at least as big as your transmap. Do not enable texture filtering.
In Poser 7, you must turn off the texture filtering on the Image_Map node instead of render settings.
In both P6 and P7, render with Min Shading Rate = .2, and Pixle Samples at least 3 to 5. If using shadow maps, use big ones, and use a spot light for closeups instead of infinite lights
pakled posted Sat, 24 November 2007 at 7:24 PM
there's some default eyebrows in some of the characters, but they go from 'singed off' to 'groucho' in a hurry.
One workaround is to download a texture or character for the model you're using. Say if you have V3, look for characters or textures in freebies (usually a woman's [or man's] name, the 'for V3'). They'll work in the short run. I've tried doing it in the transparency settings, but it's a pain...
