santolina-sailor opened this issue on Nov 27, 2007 · 4 posts
santolina-sailor posted Tue, 27 November 2007 at 11:10 AM
Hello.
How may i uninstall various poser files from my run time in Poser 6 as i need to recuperate some disc space,
Shall i do it from the main interface,ie find the posaer file I want to delete and then delete/figures,then poses/etc os simply go to the runtime folder and delete from there?
Pete
jfbeute posted Wed, 28 November 2007 at 1:52 AM
You should remove them from the runtime folders, that way you will remove everything properly.
I do hope you have actually run compression from within Poser (this will reduce your disk space a lot). If possible you can also run compression on the texture files.
santolina-sailor posted Wed, 28 November 2007 at 5:10 AM
Thank you for that.
Commpression?sounds like I missed that,
can I still do that or do I have to reinstall?
Pete
santolina-sailor posted Wed, 28 November 2007 at 7:46 AM
OK now with save compressed PZ file but not sure on textures???
Definitely a case of read the manual,but couldnt find textures.
Pete
