Forum: Carrara
Subject: Gelato
AndyCLon opened this issue on Nov 30, 2007 · 6 posts
AndyCLon posted Fri, 30 November 2007 at 4:25 AM
Following up on a previous discussion about rendering and graphics cards. I found that Nvidia have produced some software called "Gelato" which is a renderer which spreads the load between the CPU and GPU.
The question which I can't work out the answer to is, can I export data from Carrara to Gelato? There seems to be an Obj importer mentioned on the forums but that would be a bit limiting.
GKDantas posted Fri, 30 November 2007 at 5:00 AM
Gelato com read RIB files... I saw a rib exporter for DazStudio sometime but cant find. Would be good to have a RIB exporter for Carrara, many renders use this format.
http://www.nvidia.com/page/gelato_download.html
Follow me at euQfiz Digital
Patrick_210 posted Sat, 01 December 2007 at 9:27 AM
Much of what I've read about Gelato from users is not that positive. Not that fast, not that good, etc.
GKDantas posted Sat, 01 December 2007 at 9:53 AM
You are right, there some software like the Lightwaves FPrime that can do the same job and much fast.
AndyCLon posted Sun, 02 December 2007 at 11:55 AM
Quote - You are right, there some software like the Lightwaves FPrime that can do the same job and much fast.
It's a good point, what's the reason to use a GPU accelerated renderer that ends up performing slower than your CPU based one? I still think there's a future in using the GPU's facilities for rendering but perhaps it's further in the future than I thought.
GKDantas posted Sun, 02 December 2007 at 1:45 PM
I think tht GPU render is a good idea but you need a very good GPU... theres some Nvidia Gpu that is very expensive... maybe its better to get  a render farmer to do the job.
