Forum: Bryce
Subject: Bryce Manual..where do I get it?
bobbystahr opened this issue on Nov 30, 2007 · 13 posts
bobbystahr posted Fri, 30 November 2007 at 10:22 AM
For some reason when I dl'd the free 5.0 I didn't get a manual...is that the way it is...can I find a .pdf anywhere....other wize I fear most of my posting for the next wee while will be in search of answers to dumb questions more easily answered by a bit of reading, heh heh heh.. ...
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
SndCastie posted Fri, 30 November 2007 at 10:28 AM
http://www.daz3d.com/i.x/support/downloads/-/?product=bryce
They have it for the 5.5 version which should help you with the 5.0 version it is in PDF version. If the link doesn't take you there it is on daz under suport /downloads and updates for Bryce
Sandy
An imagination can create wonderful things
SndCastie's Little Haven
bobbystahr posted Fri, 30 November 2007 at 11:30 AM
Many thanks Sandy, updated to 5.5 while I was at it as well.. ...
I see a sound
bobbystahr posted Fri, 30 November 2007 at 11:36 AM
Just had a thought...will the 5.5 update screw up my free 5.0...just before I update and potentially screw it all up?
I see a sound
SndCastie posted Fri, 30 November 2007 at 12:11 PM
I am not sure bobby since I bought my 5.0 before it went free and before Daz took over we were given the 5.5 upgrade free and 6.0 was at a great discount for being a platinum member .
It does say demo so it might.
Sandy
bobbystahr posted Fri, 30 November 2007 at 12:15 PM
I'll hold off on installing it then as it mainly addresses DAZ problems and so far I don't use/haven't come to grips with DAZ Studio.....thanx Sandy.. ...
I see a sound
Incognitas posted Fri, 30 November 2007 at 12:55 PM
Hi I have 5,5.5 and 6 on my pc.I just keep them in separate files and I got all three versions from DAZ.
I don't why though...sentiment I suppose.Or am I hedging my bets that Bryce will be going backwards developmentaly?
FranOnTheEdge posted Fri, 30 November 2007 at 3:14 PM
I have B5.s and b6.0. and B6.1 and B6.1.13...whatever it is, and all of them work, and I just let them install however they wanted to.  It's always a good idea to save your presets before installing anything though, just in case.
I particularly like to have a B6 (insert extra numbers here) version as well as B5.5c, as that way I can try out things in the version without IBL as well as with IBL, in fact I'm just now doing some tests to see if using B6 with no IBL looks the same as B5.5 au naturel.
(as well as other lighting tests)
Come to think, I believe the installer says "found an earlier version of Bryce" - and then either asks if you want to install over it, or asks if you want to keep the old one too - however it phrases it - go for the option that lets you keep both.
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
Incognitas posted Fri, 30 November 2007 at 3:19 PM
Quote - I have B5.s and b6.0. and B6.1 and B6.1.13...whatever it is, and all of them work, and I just let them install however they wanted to.  It's always a good idea to save your presets before installing anything though, just in case.
There what you said..I knew there was a reason for my obsession.
FranOnTheEdge posted Fri, 30 November 2007 at 3:20 PM
Obsession is good for the soul.
(nods wisely)
Tastes sort of minty too...
Fran's Freestuff
hewee posted Fri, 30 November 2007 at 3:38 PM
bobbystahr,
Here is Bryce5_Manual_DAZ. and it says Bryce 5.0.
http://www.speedyshare.com/874764558.html
Or
http://www2.speedyshare.com/data/874764558/7632879/51985482/Bryce5_Manual_DAZ.pdf
Don't know how long they will keep the file at the site but it is there now so get it now.
Says in the readme I made that the Bryce is version: 5.0.3.0
Then I had in my notes Bryce 5 Presets you can still get here if you need them.
http://www.download.com/3000-6677_4-10589394.html
bobbystahr posted Fri, 30 November 2007 at 4:06 PM
Thank you hewee...got it fine...I got 5.5 earlier but this is better to keep confusion  at bay if the update I dl'd for Bryce 5.5 won't work.. ...
I see a sound
hewee posted Fri, 30 November 2007 at 5:06 PM
Your welcome. I got the Corel version of Bryce in a box around here someplace also that has the help files that I think were .html files too but maybe not. I don't have it installed now and it was so long ago I forget but the Help did work on the Corel version.
Ok I found it and it is a Bryce5_Manual.pdf. dated 5/24/01 and it is a little smaller file but if you want it then get the Bryce5_Manual_Corel.pdf here.
http://www.speedyshare.com/516641408.html
Or
http://www3.speedyshare.com/data/516641408/7634571/20527369/Bryce5_Manual_Corel.pdf
Where on the Daz version clicking on Help does not do anything.
But that 5.0 should be what you need and I got it back on 8/23/06 alone with two Bryce.
A Bryce5FreeVersionPC.zip that you just unzip the Bryce and it is 5.0.3.0 but you have to Registration Code to get it to work. Then I got the same day  ps_ap075_Bryce5.exe but can't tell what version it is but I think it is the same.
I think I got the one download from DAZ site and the other from C-net downloads.
