Forum: MarketPlace Customers
Subject: Need Help for using html in the long Description
AB-Grafix opened this issue on Dec 02, 2007 ยท 6 posts
AB-Grafix posted Sun, 02 December 2007 at 10:25 AM
Hi, i want to upload a new Product and will use html for the Descrition. Is there a Template, Tutorial etc. how to work this ? I know a little html and also have a Program to handle this (NetObjects Fusion) but what about the IFRAME ...?
Best way for me will be a template of anyone who uses html for his product.
I have searched the Renderosity Pages but dont find what me can help.
macatelier posted Sun, 02 December 2007 at 1:01 PM
Laetia has a good tutorial here http://www.renderosity.com/news.php?viewStory=13277
AB-Grafix posted Sun, 02 December 2007 at 1:07 PM
Oh - fast responce, thank you, it is helpfull!
AB-Grafix posted Wed, 05 December 2007 at 4:15 AM
ok, its me again, i dont understand in the Tutorial - must i set a Head- and Body Tag in the long Description Field ?
What is the correct Layout for this Field ? And what about the not allowed IFrame ?
nruddock posted Wed, 05 December 2007 at 4:05 PM
One thing that might help you get started, is to use the forum post editor to layout your information, then click on the "Source" button (at the top left of the toolbar) so that you can see (and copy) the HTML.
Keeping the formating very simple is probably going to be best for RMP use (the tag restrictions may not be quite as strict as for the forums), but the MO staff should be able to tell you what is or isn't allowed.
Bear in mind that if your item is going to be brokered via CP, the text and markup used will be used against a different style scheme, so be careful if you change colours/fonts from the default.
There are plenty of free HTML editors around (try several to see which you get along with best), including a standalone version of the one used in the forums here.
AB-Grafix posted Wed, 05 December 2007 at 4:22 PM
Ok, i try'd a litte and i think i understand something.
Is there any way to test a code on the RR Page ?
And what Kind of editors do you mean, i use for my own
Homepage Netobjects Fusion.
