FutureFantasyDesign opened this issue on Dec 02, 2007 · 10 posts
FutureFantasyDesign posted Sun, 02 December 2007 at 5:08 PM
I have several "Cloth" psd products that are in a greyscale so that you can color them as you want them. But I can never seem to get the rich colors others achieve. They come out light and washed out looking. I am sure i am doing it incorrectly, but am not sure where to locate a feature to give them "Depth" and "Rich Saturation" while maintaining the Folds and details. Anyone want to help me here?
ThanX
Ariana
Is there water in your future or is
it being shipped away to be resold to you?
Water, the ultimate
weapon...
www.futurefantasydesign.com
amul posted Sun, 02 December 2007 at 8:48 PM
Apply a hue/saturation layer with high saturation, Alternately, you can paint the colors on using a Color blending mode, which will preserve the luminosity detail but replace your color.
It would help to know how you are applying the colors. Since I've never found a reason to do this, I haven't tried myself, but I understand the theory.
They had chained him down to things that are, and had then
explained the workings of those things till mystery had gone out of
the world....And when he had failed to find [wonder and mystery] in
things whose laws are known and measurable, they told him he lacked
imagination, and was immature because he preferred dream-illusions
to the illusions of our physical creation.
-- HP Lovecraft, The Silver Key
FutureFantasyDesign posted Sun, 02 December 2007 at 9:39 PM
Well I basically have been "Flooding" the color into the material in (*don't say it, I'm still learning P/S and it's like a pacifier to go back to PSP) PSP.... I keep going back because the learning curve is very steep after using PSP for over 8 years! So I am trying to wean myself off of it... But it's hard :(
HuggerZ!
Ariana
Water, the ultimate
weapon...
thundering1 posted Mon, 03 December 2007 at 3:34 PM
Post a pic - I've never used any fabric brushes (or cloud brushes, or any other "elements" brushes), so I'm curious as to how I'd tackle it myself. But I think I need to SEE it first (and what kind of image it's being applied to can greatly affect technique as well) before giving you a comprehensive answer.
Let's see what we can all come up with for you.
-Lew ;-)
FutureFantasyDesign posted Mon, 03 December 2007 at 4:33 PM
Thank you for helping me learn...
Ariana
Water, the ultimate
weapon...
amul posted Tue, 04 December 2007 at 8:43 PM
Ariana,
I still can't answer your question until I know how you are applying your colors to the fabric. I don not understand the term "flooding." Nor do I understand what you mean by "true rich deep color."
The first thing I notice from your new post is that the range from darkest-black to lightest-white in this cloth is very shallow. Could this be why you feel the colors don't have proper depth? I assume this is what you mean by "deep color."
What you are doing is best understood in HSB color mode. The optimal way to convert this robe from one color to another without losing detail is to alter the Hue and Saturation (H and S) while leaving the Luminosity, aka Brightness (the B in HSB). Are you sure your method affects both the Hue and the Saturation? I assume this is what you mean by "rich color."
I hope this helps.
thundering1 posted Tue, 04 December 2007 at 11:10 PM
Okay, new layer on top - mode - Color. Paint a color you want the fabric to be - I used a fairly vibrant Blue. At this point you'll see the blacks go kinda mushy - at the bottom of the Layer stack, you'll see an icon that is a split of black and white - these are Adjustment Layers (AL) - click on it and choose Levels. Put it in the stack above your Brushes (but below your Color Layer). Hold the Alt key and click the line between the Brushes and the AL (and you will notice the cursor will change when you do this) - this links the AL (anything really) to the layer below so it ONLY affects the layer linked. Adjust your Levels (just double-click on the layer and the dialog box will open) to make it more contrasty - just pull in both left and right arrows to taste. This will make it more punchy.
NOW, since it still didn't look too "rich" I created an AL above the Colors layer and not only made it more contrasty, but I clicked on the little RGB at the top of the Levels Dialog Box and chose Red - pulled in the right and middle arrows to give a red sheen. Now here's the tricky part - make sure you click on the white box next to the AL layer icon in the stack, and hit Ctrl+i to "invert" the mask to black. This hides everything on that layer - why on Earth did I do this?
Get your paintbrush out, make sure you are painting white, and paint in where you want "highlights" to be in the fabric - this will make the highlights "punch" as well as give them a specular sheen that is a little on the red side, and looks a bit richer.
Once you've painted where you want all the highlights, open the dialog box again and feel free to make more changes - add more colors, etc.
It doesn't have to stop there - you can create as many ALs as you want, each for a different purpose - more highlights, even brighteneing spots of the shadows, specular colors, whatever you want - you can stack them infinitely to achieve the final look you want.
...Can you see why us Photoshop folks kind of "snicker" when we read about people who claim you shouldn't have to use any post work - that a software's renderer should be enough and you should just work harder to make it do what you want...?
Hope this helps - and lemme know if this isn't quite what you're looking for - I'll come up with something else for you.
-Lew ;-)
amul posted Wed, 05 December 2007 at 4:05 AM
.....or Lew could just explain it for me.... grin
thundering1 posted Wed, 05 December 2007 at 8:33 AM
That was my test run - you can still see the very top layer is turned off. I was moving that thing all over the place, making it different modes, and I finally realized "hey, just use it for Color and use ALs to make it vibrant..."
-Lew ;-)
FutureFantasyDesign posted Wed, 05 December 2007 at 9:07 AM
That is exactly what I was going for Thundering1!!! The color is deep and "Rich" very DENSE!!! Gads it is hard to describe something when it is foreign to your experience and you are transitioning from one program to a totally different program in every aspect!!! :P
Good basic Tut too! Cause I am a dum bunny about PS!
OK, I will be trying this out in a day or so, I got some bad news on Monday, and then yesterday found out my dog has Lymphnoma, and we aren't sure, but we might have to put him to sleep in the next few days...it hit fast and severly. Last nite he almost suffocated to death because of the swollen Lymph Glands. It is very stressful, I am up for a Vet call... I will work on this stuff as life permits. But I appreciate the help, it IS exactly what I was asking about.
Thank you as well Amul!
Ariana
Water, the ultimate
weapon...
