santolina-sailor opened this issue on Dec 07, 2007 ยท 3 posts
santolina-sailor posted Fri, 07 December 2007 at 10:26 AM
Hell.
Recently I had to reinstall both version of Poser (5 and 6) since then I cant access the poser 5 runtime from poser 6.
What am i doing wrong?
Pete
Tashar59 posted Fri, 07 December 2007 at 10:37 AM
You need to add your P5 runtime to P6.
In your library tabs you will see a (+) on the bottom. scoll on it and it should say (add runtime) and click and add your runtimes. If it does not say that, then you need to tab up to the top. There will be a folder that has an arrow pointing up. Click on that untill there are no more of those and then your (+) sign at the bottom will be the right one to use.
santolina-sailor posted Fri, 07 December 2007 at 10:46 AM
Wonderfull!!!
Thank you very much for your help and time.
Pete
