diolma opened this issue on Dec 08, 2007 ยท 9 posts
diolma posted Sat, 08 December 2007 at 4:18 PM
What is causing the very obvious line between the "Arm" and the "Forearm"?
It's almost as if the mesh wasn't welded at that point, but I can't believe that.
The Arm and the Forearm use an identical texture map and settings for bump, specularity etc. The same thing happens at one other point (although that may be my fault), but other than that all the "joins" seem to be working perfectly.
Any suggestions??
Cheers,
Diolma
