AnAardvark opened this issue on Dec 10, 2007 ยท 1 posts
AnAardvark posted Mon, 10 December 2007 at 10:45 AM
I'm seeing some odd behavior. When I set it to render in an external process, with four threads, it looks like it is only rendering with one thread (picture fills in from left to right, top to bottom), but it stops rendering partway through, but the FFErender process is active. When I set it to render within the main process, it looks like it is rendering with four threads (picture fills in each quarter at the same time), but the FFErender is not active. It also crashes with a C++ error. Is it possible that my configuration file is wonky? Can I remove it and it will rebuild, or should I go in and tweak it.
thanks.
