jjroland opened this issue on Dec 11, 2007 · 17 posts
jjroland posted Tue, 11 December 2007 at 1:58 PM
I sent a site mail to him too. But Im curious if anyone here knows if that product will create mat poses for props as well as figures. If it will create mat poses for V4 and if it will work in P6.
It says in the readme that it will create files for P6 but are they just as good as any created in P6?
I'm sure it is a great product, I just want to know before purchasing if it will do specifically what I want it to do.
I tried the tutorial and for some reason it just wont work for me and I don't have the time to mess with the files for hours.
Thanks in advance!
I am: aka Velocity3d
Paloth posted Tue, 11 December 2007 at 2:10 PM
There was a thread here that mentioned Mat pose won't work on a props unless there's a figure in the scene. That implies that Mat poses can be created for props, even though poses are usually just for figures. I don't know if Hoaglands Mat Pose Creator will work for props.
BAR-CODE posted Tue, 11 December 2007 at 2:11 PM
.. i dont know this one ..got a url ?
Chris
Edit for dumb text ;}
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
BAR-CODE posted Tue, 11 December 2007 at 2:13 PM
if you make props for use in Poser ..dont use mat edit ..use MAT files then the props work fine without being parented..
Chris
Chris
vincebagna posted Tue, 11 December 2007 at 2:14 PM
Why do you need this to make MAT Poses? It's very easy to make it by hand ^^
mrsparky posted Tue, 11 December 2007 at 2:18 PM
Attached Link: http://market.renderosity.com/mod/bcs/index.php?ViewProduct=5174&
Yes it does make MAT poses for props.It even has some entrys for some of the props in Poser. (see screenshot).
Yes it will work with V4 and P6 - and works with P7.
Link above.
jjroland posted Tue, 11 December 2007 at 2:27 PM
Wow incredibly fast replys!!! Thanks!
Vince it was your tutorial that I tried. I know your method works - works fine for a friend and many others. For some wierd reason it wont work for me. I can't imagine what I am doing wrong. I change the two lines (6>4.01) and the materialcollection word. Just will not work when I go to apply > nothing happens.
Reason I want to make mat poses for the prop is because there is more than one. If I had just one than I would simply save the prop with that one and not be worried.
For this particular prop there will always be a figure in the scene when using it, so if that is a hold back, it is easily overcome.
Thanks very much for your replies.
Paloth posted Tue, 11 December 2007 at 2:31 PM
Is there a reason why displacement maps don't appear as an option is the program's configuration? (Could it possibly be so old that displacement maps weren't included?)
vincebagna posted Tue, 11 December 2007 at 3:26 PM
JJ - Was it for a prop? If so, have you looked at the internal name of the prop and put it instead of mtlcollection? It doesn't work the same for a prop or a figure.
Also when applying a MAT pose to a prop, it MUST have a figure too in the scene as you said, but this figure HAS to be loaded first in the scene.
jjroland posted Tue, 11 December 2007 at 4:12 PM
I tried it on both a figure and on a prop. I followed your instructions for each - meaning yes I put the exact prop name in that line when working with the prop.
It worked for neither the prop or the figure.
msg24_7 posted Tue, 11 December 2007 at 4:49 PM
It's not necessary using the exact prop name within the matpose.
Just use the expression actor $CURRENT
Now you can apply the MATPose to the currently selected prop.
It's better than using the exact name of the prop, because that may
change, when loading more than one of those props into a scene.
Yesterday's the past, tomorrow's the future, but today is a gift. That's why it's called the present.
vincebagna posted Wed, 12 December 2007 at 1:48 AM
Thanks msg24_7! Very useful info!! ^^
It doesn't change the problem of prop not taking MAT pose when no figure in scene, but it fixes the prop name problem :)
I'll update my tut with that info ^^
msg24_7 posted Wed, 12 December 2007 at 4:30 PM
Quote - ...
Earlier in this thread it was mentioned, that a figure needs to be in the
scene prior to loading the prop.
At least in Poser 7 it doesn't matter at what time you add a figure to the scene.
Martin
ruby_dragon posted Wed, 12 December 2007 at 7:08 PM
MAT Pose Creator v. 4.0.0 - Yuppers, you bet it works with V4 :-) Works very well in fact!!
ashley9803 posted Thu, 13 December 2007 at 12:41 AM
Have a look at this tute. It's really very simple to do yourself.
JHoagland posted Thu, 13 December 2007 at 12:29 PM
Replied to jjroland's site IM on the 11th.
The program was designed for use with Poser 4 and can create Poser 5 style MAT poses. It does not include any advanced material features such as procedural nodes, displacement, ray-traced reflections, etc.
Yes, the program can create MAT poses for props, but due to Poser's feature/ glitch, MAT poses will only work on PARENTED props. MAT poses do not work on non-parented props.
msg24_7 posted Thu, 13 December 2007 at 5:07 PM
Quote - .....MAT poses will only work on PARENTED props. MAT poses do not work on non-parented props.
I think, that's not quite correct.
Using "actor $CURRENT" instead of the prop name within the MATpose file, a MATpose can
be applied to a prop, as long as a figure is present and the prop is currently selected.
No need for the prop to be parentend to anything.
This works at least for Poser 5 and up. I don't know about Poser 4 or PP.
Martin
