Forum: Carrara
Subject: Has "MIXER" changed in Carrara 6.03?
Nate opened this issue on Dec 12, 2007 ยท 3 posts
Nate posted Wed, 12 December 2007 at 10:17 PM
Something I've done many times before C6 was to mix colors using checkers... to get a pattern of checkers or lines alternating between two colors.
This image is done with Carrara 6.03
The dialog box (see image) shows the right effect, but that is not what is in the image or the render....
Does this work differently now, or am I missing something... or is this a remaining fix for a future patch of Carrara???
On-line portfolio / Making figurines in China / Gallery  / Video Demos
Nate posted Wed, 12 December 2007 at 10:34 PM
EDIT: Works now... my example was using an imported .3ds cube.... any thoughts on why that wouldn't work?
MarkBremmer posted Wed, 12 December 2007 at 11:14 PM
Hi Nate, More than likely it was a UV issue on the geometry. Resetting the UV map in the Vertex room will fix it. Mark
