Subject: V3 foot morph
speedgoat opened this issue on Dec 13, 2007 ยท 3 posts
speedgoat posted Thu, 13 December 2007 at 11:58 AM
Hi
Is there a morph to fit V4 Shoes on a V3 Figure?
And if not: Does anyone know how to do it?
Thanks!
EnglishBob posted Fri, 14 December 2007 at 5:12 AM
There are several options. If you're willing to use V3 clothes, and forgo body morphs, there is a V4 to V3 figure which you should have if you bought anything other than the basic V4 (I think). Prop shoes can often be fitted to a different figure by scaling and translating them; tough cases may need some work with magnets too, and/or postwork. Conforming shoes can be converted to props and refitted as above - just export as OBJ, and reimport with all the boxes unchecked. You'll probably need to reapply textures etc.
BastBlack posted Fri, 14 December 2007 at 10:28 AM
V4's foot is arched for high heels, V3's is not. I have been able to get some decent V4 boot to M3 conversions with Wardrobe Wizard 2. For example, I converted Florentine Hunt boots to M3 with WW2. There is a tutorial at PhilC's that explains the different style of shoe conversion you can try. For Florentine Hunt, I choose "High Heels". That will keep the high heel shape to the boot. I just had to turn off M3's foot and toe in the Hierarchy folder (if you don't the feet and toe will poke out of the boot). Using this method, you can convert shoes from V4 to V3, but if it is a strappy sandal with the foot and toe showing, you need to use the other method of WW2 shoe conversion. Make sense? bB
