Subject: HOW to "save as .pz2" with an .mc6
jjroland opened this issue on Dec 17, 2007 · 18 posts
jjroland posted Mon, 17 December 2007 at 10:40 AM
Someone please answer this!!  It is absolutely driving me nuts.
When I open the .mc6 in notepad I don't have option to "save as"  anything other than .txt
If I change the file name (ie rename) from file.mc6  to file.pz2 it doesn't change anything except the name, the file is STILL a .mc6.  Is there some file conversion utility that I need to be using???
Thanks in advance.
I am:  aka Velocity3d
kuroyume0161 posted Mon, 17 December 2007 at 11:01 AM
Just change the extension when using "Save As..." and it will be saved thusly.  The second option, "Save as Type",  is just a display filter for the current folder contents shown in the file dialog box.
 -- Bjarne Stroustrup
adp001 posted Mon, 17 December 2007 at 11:06 AM
http://www.scintilla.org/SciTE.html
Use this as editor insteed of notepad. It's free, works with very large files and is - just wonderfull! :)
onnetz posted Mon, 17 December 2007 at 12:17 PM
I've been working on this program off and on for a while and its still deep in beta mode but it will convert material files into mat pose files. You can do a single file or batch convert a directory. It will also read compressed or uncompressed files.  There is an option to save as a compressed file but that doesnt work just yet. Its written in java so if you have a current version of the java runtime it will work.
http://onnetz.spiritbones.org/PoserHelper.zip
Handle every stressful situation like a dog.
If you can't eat it or play with it,
just pee on it and walk away. :-)
I wouldnt have to manage my anger
if people would manage their stupidity......
jjroland posted Mon, 17 December 2007 at 12:29 PM
Thank you for the replies.  It's nice to know how to just use the plain ol "save as" Kuro =D
As an added solution to this problem Ockham has a python script that will do this also.
(it's good to have more than one solution to any problem ; )
Thank you for the program link Onnetz and thanks for the text editor link ADP.
onnetz posted Mon, 17 December 2007 at 12:50 PM
In notepad if you put quotes around the filename it will save it as whatever you name it.
SSAfam1 posted Mon, 17 December 2007 at 12:53 PM
Is there a difference between MAT pose files and Pose files?
jjroland posted Mon, 17 December 2007 at 12:54 PM
mat pose is the texture
pose is the pose
I think
SSAfam1 posted Mon, 17 December 2007 at 1:08 PM
But the textures are the same used in a pose. Like for instance, if you have a runtime with pz2 files, the textures for those files will be in you texture folder. It's just sometimes you get textures and no pz2 file. The merchant didn't save them to poses for convience so you'll need to apply textures manually in the Material Room.
You know how you can only apply materials in Material room? Is the mat pose the one you can only apply there or is it like a regular pose (pz2) file where you can apply in any room?
onnetz posted Mon, 17 December 2007 at 1:51 PM
basiclly a mat pose file is a material room file converted to be used in the pose folder so you dont have to go into the material room to apply it.
SSAfam1 posted Mon, 17 December 2007 at 1:58 PM
Oh so in the end it's a pz2.
onnetz posted Mon, 17 December 2007 at 2:08 PM
yes. to convert a material file to a mat pose file you change the file extension and about three lines of code at the beginning of the file. And of course put it in a pose folder.
SSAfam1 posted Mon, 17 December 2007 at 2:16 PM
Simple enough. Thanks.
adp001 posted Mon, 17 December 2007 at 2:18 PM
Why not leaving the material file where it is? If you like to have something that helps flooding your pose folder, just do a "wrapper" (small pz2) containing a readscript statement.
I HATE this millions of MAT-pose files in my pose folders. I would love to see all materials in my material-room. At least if a product says: "Poser 5/6/7".
jjroland posted Mon, 17 December 2007 at 2:45 PM
ADP I think that would be nice for me as well.  I assume however that there are probably thousands of poser users who have never so much as opened the materials tab.
People would lose thier heads if they opened up thier pose folders and all those beautiful clickies were in another place : p
Conniekat8 posted Wed, 19 December 2007 at 7:48 PM
Onnetz, THANK YOU SO MUCH for that utility, it works like a charm!!!!!!!!!!!!!!!!!!!!!!!!!!
mwah
Hi, my namez: "NO, Bad Kitteh, NO!"  Whaz yurs?
BadKittehCo Store  BadKittehCo Freebies and product support
onnetz posted Wed, 19 December 2007 at 9:36 PM
Quote - Onnetz, THANK YOU SO MUCH for that utility, it works like a charm!!!!!!!!!!!!!!!!!!!!!!!!!!
mwah
your welcome.....:-)
glad you found it useful, eventually I will add more functionality to it.
wdupre posted Wed, 19 December 2007 at 10:02 PM
Quote - Why not leaving the material file where it is? If you like to have something that helps flooding your pose folder, just do a "wrapper" (small pz2) containing a readscript statement.
Poser 5 doesn't recognize mc6 files so you have to limit them to Poser 6 and 7
