mhscspo opened this issue on Dec 19, 2007 · 11 posts
mhscspo posted Wed, 19 December 2007 at 12:47 PM
I'm trying to install the patch in Vista Ultimate 64, it keeps saying unable to locate application file, anyone using Vista can help me on this one?
bruno021 posted Wed, 19 December 2007 at 1:53 PM
Did it work with previous updates? Are you running Vue as administrator?
FrankT posted Wed, 19 December 2007 at 2:13 PM
you might want to hold off on this update - there is a problem with it. E-On will be releasing an update for it soon
mhscspo posted Wed, 19 December 2007 at 7:26 PM
Quote - Did it work with previous updates? Are you running Vue as administrator?
[No I wasn't, but I am now Thanks..
mhscspo posted Wed, 19 December 2007 at 7:28 PM
Quote - you might want to hold off on this update - there is a problem with it. E-On will be releasing an update for it soon
Ok!
ShawnDriscoll posted Wed, 19 December 2007 at 7:33 PM
What problem is that?
dlk30341 posted Wed, 19 December 2007 at 7:36 PM
Older scenes crashing & working in the material editor causing crashes.
ShawnDriscoll posted Wed, 19 December 2007 at 7:39 PM
I had not realized a patch came out again so soon. Thanks. I'll wait then.
Arraxxon posted Wed, 19 December 2007 at 9:19 PM
I've had no problem to install the newest build 292300 on my Vista Ultimate 64bit - i don't run Vue in administrator mode, but still Vue and all updates are working fine, so it's not a necessity.
The offical, non-beta state version of Vue Infinite is version 6.10 build 291050.
Nevertheless, the version 6.50 and all it's build-versions are still in beta, so errors/problems can be part of it. By finding and reporting errors you will help to get this version into a final offical version status in the near future.
One of the problems with the newest beta-update build 292300 on Vista 64bit - with or without the newest Vista SP1 Release Candidate 1 update installed - is a problem with material assignment to any object.
This will be taken care of right now, as it got reported right after the release of build 292300.
To get rid of those problems for now just roll-back to the before beta version build 292230.
wabe posted Thu, 20 December 2007 at 1:08 AM
Could it be that you try to use an update on the prerelease version? Sounds a bit like. If so, get the final version at e-on as download and try it with that.
mhscspo posted Thu, 20 December 2007 at 2:37 PM
Quote - Could it be that you try to use an update on the prerelease version? Sounds a bit like. If so, get the final version at e-on as download and try it with that.
Thanks for the feed back, I got it to work by using "use as admistrator", this is the first time that I used Vista..
