Subject: Help! I am getting "an error occured while processing the binary morph delta da
datastorm opened this issue on Dec 20, 2007 · 3 posts
datastorm posted Thu, 20 December 2007 at 11:10 PM
I get this error "an error occured while processing the binary morph delta data. There mabe insufficent memory to process the data or PMD file is invalid".
I am currently using poser 6 with the poser 6 upgrade. computer is dual core with 1GB of memory. video card is ati radeon with 256mb of memory.
This problem only occurs with V4.1.      V3 and all other characters work fine with no problem.
This problem seems to happen when I have saved a V4.1 file to my hard drive and then try
to open it.
If someone could let me know what this error means and how to correct it.
Thanks
dataflow
pjz99 posted Fri, 21 December 2007 at 1:37 AM
Make sure to download and install the latest update for V4.1, although it may be that even the current version for download still does not have this fixed.  There is a version that many people downloaded that had buggy morph data in the head (PHMIrisConvexity I believe) and it sounds like this is your problem.
My Freebies
chris1972 posted Fri, 21 December 2007 at 5:39 AM
I would suggest turning off the storage of external binary morph targets. You will find this under general preferences/misc, uncheck use external binary morph targets. I always was unable to open poser files I had created untill I disabled this. Since I have had no more problems.
I have no idea why it's even there.
