hamiltonpl opened this issue on Dec 22, 2007 · 5 posts
hamiltonpl posted Sat, 22 December 2007 at 9:47 AM
I have created some label in photoshop to place on certain items. Lettering is included. However the lettering is readable only when you're zoomed in otherwise it appears as a blur. To partially correct I remove texture flitering. But still you'll get the letter H withough the crosshatch in the middle, etc.
Is there a certain font that works better on this? I can't seem to get good results with the lettering showing up satisfactorily.
By the way in preview mode - aside from the artifacting the lettering looks fine from any distance. It seems to be the firefly render. Suggestions?
Windows 10 - Poser Pro 2012 - 64Bit - 24GB RAM - 4 x 3.40 GHZ processor
squid69 posted Sat, 22 December 2007 at 9:58 AM
Don't know if this is much help but: texture filtering off as you mentioned, Shading Rate less than or equal to 1, pixel samples around 3 X 3. Regarding your font, you can either BOLD it, or choose a font with less contrast between the strokes such as Garamond, Egyptian or Helvetica.
hamiltonpl posted Sat, 22 December 2007 at 10:11 AM
Thank you. Shading rate 1.0 pixel samples 3 works great. If you change the shading rate to 1.25 then the H doesn't render correctly. This seems to help and I appreciate it....
ockham posted Sat, 22 December 2007 at 11:23 AM
If you can switch to the 'Poser 4' renderer, text always looks best there,
with no fiddling needed. Of course if you're using ray-tracing or
fancy lighting, you can't make that change.....
Huolong posted Mon, 24 December 2007 at 4:42 AM
On Poser 7 change the quality of each texture from "quality" to "none" in the materials room ... makes a huge difference
Gordon
