Subject: Face morphs not working
flibbits opened this issue on Dec 27, 2007 · 12 posts
flibbits posted Thu, 27 December 2007 at 6:04 PM
I've recently downloaded a few face morphs for M3 and D3.  While waiting for the creator to answer, maybe someone here knows a fix or cause of this problem.
When the face morphs are applied, the only thing that changes are the eyes.  The get bigger or smaller, but the face doesn't morph.
Any ideas what can cause that?
BeyondVR posted Thu, 27 December 2007 at 8:58 PM
The morphs are probably based on the morph packs from DAZ3D.  If you do not have them installed, that would explain the problem.
John
flibbits posted Thu, 27 December 2007 at 9:03 PM
By "the morph packs from Daz3D" do you mean the head morphs for M3 and D3?  I have both the head an body morphs, from Daz, for those characters.
Maybe it's because those aren't installed in the base runtime, but rather in a Michael3 runtime?
BeyondVR posted Thu, 27 December 2007 at 9:14 PM
That could possibly be it.  I have P6 and have the !DAZ folder under my main runtime, but M3 and D3 in their own.  That setup works for me.
John
infinity10 posted Thu, 27 December 2007 at 9:20 PM
For me, what works is that the external runtime with the !DAZ morph injection folders be included in the library runtimes ( I speak from POser 6 and 7 experience only ).  Poser wil then look into those external runtimes as well for the morphs.
Eternal Hobbyist
onnetz posted Thu, 27 December 2007 at 9:31 PM
Open up the pz2 file in a text editor and see if its referencing files such as the daz morphs.
If it is then the path should start with
:Runtime
and not
C:some obscuredark areaof a hard drive
Handle every stressful situation like a dog.
If you can't eat it or play with it,
just pee on it and walk away. :-)
I wouldnt have to manage my anger
if people would manage their stupidity......
Acadia posted Thu, 27 December 2007 at 9:41 PM
I've had some character morphs that require you to inject the head and body morphs before injecting the morphs from the character package.
Try injecting the head morphs for M3 before injecting the ones for the character addon and see if that helps.
Acadia posted Thu, 27 December 2007 at 9:43 PM
Quote - Maybe it's because those aren't installed in the base runtime, but rather in a Michael3 runtime?
That is ok. Just make a copy of the !DAZ folder and put it in the same path in the Poser 6 folder.
flibbits posted Fri, 28 December 2007 at 1:41 AM
I thought of injecting the head morphs first and then read it here.  I'll try that and report the result.
flibbits posted Fri, 28 December 2007 at 3:25 AM
That was it, the Daz head morphs had to be loaded first for the new morphs to work.
Thanks everyone for the suggestions.
Chipperz posted Sun, 30 December 2007 at 9:40 AM
I'm having the same problem!!! I have V4.1 Complete and when I apply the Head,Body,or full
Inject nothing seems to happen. I'm trying out Rhiannons BladeRune. I'm assuming my V4.1 model already has the correct head and Body Morphs.I loaded all in Poser7 main Runtime.
or do I need additional Morphs??
Acadia posted Sun, 30 December 2007 at 9:59 AM
Quote - I'm having the same problem!!! I have V4.1 Complete and when I apply the Head,Body,or full
Do you have this package? If not you need it to use character addons
http://www.daz3d.com/i.x/shop/itemdetails/-/?item=4787&spmeta=rq
