Subject: Rendering Shadows only for figures
hamiltonpl opened this issue on Dec 29, 2007 · 5 posts
hamiltonpl posted Sat, 29 December 2007 at 10:45 AM
I created an animation that looks great except the shadows hardly show on the prop ground I am using.  I want to make an extra pass at the animation but just render the SHADOWS ONLY on the groung using Current BG Shader in the render settings so I can overlay this onto the anmimation.
In order to do this I need to create stronger lighting. I do not want to render figures or anything else - I need these invisible but to get the shadows I need the figure ON.  Is there a setting or way to have the figures cast shadows only?
Windows 10 - Poser Pro 2012 - 64Bit - 24GB RAM - 4 x 3.40 GHZ processor
Acadia posted Sat, 29 December 2007 at 10:55 AM
In the firefly render window, check the box next to "cast shadows only", and that should work.
hamiltonpl posted Sat, 29 December 2007 at 11:06 AM
Yes that works EXCEPT it creates the shadows on a white background. Since I will be compositing I prefer to have this on a transparent background like you get when you render to images (PNG).  I can do it this way but then I will be forced into chromakeying out the white background. Is there a way to have the shadows ONLY without the background?  My settings are Render Over:current BG shader with the Shadows Only box checked. tks.
Acadia posted Sat, 29 December 2007 at 11:22 AM
Save it as a .png file and then in your graphic program apply the shadow  image to itself as a mask in order to get rid of the background.
hamiltonpl posted Sat, 29 December 2007 at 11:32 AM
I have 72 frames of this so that is not workable.....I have found a way using shadow catch in the materials room - it gives me what I want but I have dozens of mats that would need this turn on for.  Don't suppose you would know of a script that would do this? There is a wacro setup but it only affects the current mat.....just like checking the box --- surely there is a way to apply to all mats....
