Subject: Custom morphs - how to make poses?
Black_Star opened this issue on Dec 30, 2007 · 4 posts
Black_Star posted Sun, 30 December 2007 at 4:36 AM
Hi!
I have finally made my first custom morph for A3, and now I can't make an INJ pose for it.
I have imported all the .obj parts for all the body parts in Poser, so now I have a file with A3 and and a morph that affects her entire body.I have made 1 all the dials of that morph.
Now, how can I make an INJ pose of it?
The only way I knew was InjPoseBuilder, but in this case nothing happens (btw, it hadn't a seed for A3 too? after the last install I can't see a seed for A3).
Then tried PLH, but the settings for that program looks like hell.
In conclusion, I have saved from Poser the .cr2 file morphed in e:/Poser VG/../character/My character/My character.cr2
My Poser (the .exe file) i located in c:/Program Files/e-frontier/Poser 7/
My Aiko 3 is located in e:/Poser 5/Runtime/..(the usual path)
I want to save my INJ in e:/Poser VG/../Poses/My character/
Now, knowing all these, what should I set and how in PLH?
Do you know any other way of making the INJ file for a custom morphed character?
Thank you in advance!
Best regards!
BeyondVR posted Sun, 30 December 2007 at 8:18 AM
Attached Link: INJ/REM
I have no idea what PLH is.  I did this tutorial a couple of years ago, and it may help you whether you do it by hand or use a utility.
BTW, I don't use Aiko, but I don't see an .ill file for her in IPB either.  I have plenty of them for other figures I don't use, but there should be one available for her someplace.  You may be able to create one for her within IPB, but I don't know the procedure.  Good luck!
John
jonnybode posted Sun, 30 December 2007 at 8:25 AM
Hi!
If A3 counts as one of the Millenium 3 figures maybe you can try Svdl's SpawnCharacterP6 script, it makes an INJ / Rem file and its available for free at the phytonforum on this site.
Ive only tried it on V3 but it worked like a charm, Svdl rocks :-)
Regards / Jonny
Black_Star posted Mon, 31 December 2007 at 7:04 AM
"I have no idea what PLH is"
 - Is Pozer's Little Helper 6.0 beta
"You may be able to create one for her within IPB, but I don't know the procedure."
 - I have already tried that, but it doesn't work.Actually, I don't know what it doesn't work, the creation of the .ill or the use of it in IPB.I have created one for A3, but I don't know if it works or not, since the INJ doesn't.
"If A3 counts as one of the Millenium 3 figures maybe you can try Svdl's SpawnCharacterP6 script, it makes an INJ / Rem file and its available for free at the phytonforum on this site."
Thank you all!
Best regards!
