Forum: Carrara
Subject: The Ocean Primative, how do I use it?
Tomsde opened this issue on Dec 31, 2007 · 8 posts
Tomsde posted Mon, 31 December 2007 at 2:31 PM
I've really been struggling with Carrara 6 and am regretting that I spent the money for the upgrade.  When I put an ocean primative in a scene it seems very small and with an atmosphnere it doesn't stretch to the horizon line because it's not an infinite plane.  How do I use the ocean primative and make a realistic ocean?
GKDantas posted Mon, 31 December 2007 at 2:40 PM
use the replicator. just simple.
Follow me at euQfiz Digital
Jedi_Padawan posted Sun, 30 March 2008 at 10:51 AM
May I add my question regarding the replicator?
I've got this wonderful ocean file from naniwa (see this thread http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3172757&ebot_calc_page#message_3172757) and tried to make it stretch to the horizon with the surface replicator, but somehow I still don't get it right. Just some random patches on the infinite plane which I added as the source object. Even when I raise the number of objects to 1000 it's still not enough. Perhaps I've tried too many things out that I can't think now of the easiest option....
Could someone please help me with the correct settings in the surface replicator in order to get an endless ocean?
Thanks a thousand times!!!
~Sassy~
GKDantas posted Sun, 30 March 2008 at 12:37 PM
Endless you will never get... you are using replication, so you need to change a little you camera view to make the ocean grid match the horizon.
Patrick_210 posted Sun, 30 March 2008 at 2:00 PM
You can change the settings of the ocean object to get a very large ocean, not infinite, but pretty large. I suppose you could duplicate 2 or 3 more if you wanted to increase it even further. Change the scene scale in the realstic sky to 5 miles or more and raise the haze altitude and density to blur the horizon.
Patrick_210 posted Sun, 30 March 2008 at 2:02 PM
> Quote - You can change the settings of the ocean object to get a very large ocean, not infinite, but pretty large. I suppose you could duplicate 2 or 3 more if you wanted to increase it even further. Change the scene scale in the realstic sky to 5 miles or more and raise the haze altitude and density to blur the horizon.
Here are the settings. I started with a large scale scene.
Patrick_210 posted Sun, 30 March 2008 at 2:05 PM
Quote - May I add my question regarding the replicator?
~Sassy~
Just use the replicator, not the surface repliactor.
Jedi_Padawan posted Sun, 30 March 2008 at 9:03 PM
Thank you all so much for your tips! When I'm back home from work I'll definitely try this out.
Patrick, that looks exactly like what I wanted to do :o)
And even posting the settings you've used is HIGHLY appreciated!!!!!!!!!!!!!!!! THANK YOU!!!!!!!!
~Sassy~
