atilla39 opened this issue on Jan 01, 2008 · 10 posts
atilla39 posted Tue, 01 January 2008 at 2:29 PM
Another problem with poser 7. Poser keeps getting a windows error and closes every time a final render finishes. I can render all day in the pose room and nothing happens. I usually render at 2000x2000...200psi. It only happen when a final render finishes. Could someone please help me if you can. Thanks
Jumpstartme2 posted Wed, 02 January 2008 at 1:58 AM
Are you using Firefly or Poser4 Render? Also, have you tried using them both?
~Jani
Renderosity Community Admin
Ondoval posted Wed, 02 January 2008 at 2:05 AM
It could be memories issue.
Could you give us youre specs ? and the error message.
For art to exist, for any sort of aesthetic
activity to exist, a certain physiological precondition is
indispensable: intoxication.
We have art in order not to die of the
truth.
Friedrich Nietzsche
atilla39 posted Wed, 02 January 2008 at 9:53 AM
I'm using the firefly renderer. I did not try the P4 render to see if it would happen but I will.
I'm using a 2.40 gigahertz AMD Athlon 64x2 Dual Core Processer
2 gigs ram
Geforce 6600 255mb ram
Its an error message that just says that it has encountered an error and is shutting down and asks if I want to send it to Mr. Bill Gates.
atilla39 posted Wed, 02 January 2008 at 9:55 AM
Oh and I'm just using the default settings for Firefly.
Plutom posted Wed, 02 January 2008 at 5:09 PM
I reread your problem about being able to render in the Pose room so my idea won't work and once you do a reply you can't delete it. For what its worth, my problem was a 3rd party hair piece, Poser simply closed in about .3 micro seconds, no warning. Plutom
nruddock posted Wed, 02 January 2008 at 5:56 PM
Quote - ... my problem was a 3rd party hair piece ...
Which one ?
It may be possible to determine what's causing the problem and come up with a fix.
Plutom posted Wed, 02 January 2008 at 6:51 PM
It was the two bangs of the Leolin Hair that caused my problem. I simply deselected the bangs and used the rest--now I have my Amanda Tappin (AKA Samatha Carter-StarGate look alike). At lease those bangs and my Poser 5 don't get along.
atilla39 posted Wed, 02 January 2008 at 8:03 PM
Its doing it on every thing I render. I just may have to try and reinstall and start over. There has to be a conflict with something I just can't figure it out. Thanks
Plutom posted Thu, 03 January 2008 at 8:58 PM
Pagan7Artist had a problem with Poser 7 crashing see his/her thread if your re-installed didn't work. Plutom
