WarKirby opened this issue on Jan 01, 2008 ยท 4 posts
WarKirby posted Tue, 01 January 2008 at 11:28 PM
I needed a higher res version of a very small, blurry logo. So I used this site to create a vector of it.
http://vectormagic.stanford.edu/
Once it was done, I downloaded in .eps format, opened in photoshop, did editing, cutting as necessary, and went to save as .tga .
Only, the option wasn't there. After a bit of poking about, I think I found why, under the channels tab, instead of the usuall RGB, Red, Green, Blue, it has CMYK, Cyan, Magenta, Yellow, and Black.
How do I convert it to RGB so I can save it as a .tga ?
Edit: I'm using photoshop CS2, in case it's important.
bikermouse posted Tue, 01 January 2008 at 11:43 PM
I know this is a stupid question, butr couldn't you convert it to tga before you bring it into photoshop in say, infranview?
bikermouse posted Wed, 02 January 2008 at 12:51 AM
OOPS !! forgot - you'll have to use the afpl ghostscript plugin with infranview for eps files: you can get it here. look down to POSTSCRIPT. there will be a link.[
http://www.irfanview.com/plugins.htm](http://www.irfanview.com/plugins.htm)
tantarus posted Wed, 02 January 2008 at 3:18 AM
Image - Mode - RGB :)
Tihomir
Open your mind and share the knowledge!
