Zak666Williams opened this issue on Jan 04, 2008 · 23 posts
Zak666Williams posted Fri, 04 January 2008 at 12:49 PM
dose anyone know of a good tutorial for underwater scenes?
of where i could get a free one?
Peggy_Walters posted Fri, 04 January 2008 at 1:13 PM
I have one - it's based on Vue 5, but will work just as well in Vue 6.
http://users.tns.net/~mwalter1/caustics.pdf
Then, take a look over at GeekatPlay. Lots of tutorials and one on underwater.
http://geekatplay.com/index.php See tutorial #30
P.S. My tutorials will not be available on my site for much longer - I will be moving them to ShareCG (they host for free and are quick for downloads).
Peggy
LVS - Where Learning is Fun!
Valerie-Ducom posted Fri, 04 January 2008 at 1:29 PM
Excellent links and really good tutorials ! Thanks Peggy_Walters
Zak666Williams posted Fri, 04 January 2008 at 1:40 PM
Dam i can't open the link for the first one.
Zak666Williams posted Fri, 04 January 2008 at 1:44 PM
I had a look at the tutorials on the greek site, but In Vue 6 Esprite i cant find the option in eadeting materials that lets you create your own ecosystems.
but the underwater one wont run on my pc for some reaseon.
Valerie-Ducom posted Fri, 04 January 2008 at 1:52 PM
Quote - Dam i can't open the link for the first one.
I can open it... it's in .pdf.
For Vue6 infinite, I don't know, but work good in vue6 XS
Valerie-Ducom posted Fri, 04 January 2008 at 1:58 PM
Zak666Williams posted Fri, 04 January 2008 at 1:59 PM
i've got it now, thanks for the PDF
Now i need a Tutorial for Vue 6 Esprite forgenerating your own ecosystems like in Xstream
alexcoppo posted Fri, 04 January 2008 at 2:08 PM
Quote - Now i need a Tutorial for Vue 6 Esprite forgenerating your own ecosystems like in Xstream
If you Esprit without additional modules, you can only populate an ecosystem created by someone else. In order to create ecosystems, either get just the Ecosystems additional module (or Vue Pro).
Bye!!
P.S.: instead of Bye I wrote Buye!!! great freudian lapsus, isn't it?
GIMP 2.7.4, Inkscape 0.48, Genetica 3.6 Basic, FilterForge 3 Professional, Blender 2.61, SketchUp 8, PoserPro 2012, Vue 10 Infinite, World Machine 2.3, GeoControl 2
Valerie-Ducom posted Fri, 04 January 2008 at 2:13 PM
Quote - i've got it now, thanks for the PDF
But.. do you have Vue Esprit or Vue XS ?
Quote - P.S.: instead of Bye I wrote Buye!!! great freudian lapsus, isn't it?
:lol:
Zak666Williams posted Fri, 04 January 2008 at 2:20 PM
I've reasently got Vue6 Espite And I think i might just go bye that dam modual.
Valerie-Ducom posted Fri, 04 January 2008 at 2:28 PM
I don't know this version, sorry.. But the process, I think, still the same...
Zak666Williams posted Fri, 04 January 2008 at 2:29 PM
in the materials eaditor under the types of material under the one starting with V there is no Ecosystem like in Exstream so Esprite can not do this (DAM)
Valerie-Ducom posted Fri, 04 January 2008 at 2:47 PM
well... Do you have some material in ecosystem with sub-marine system ? or do you have nothing like that ?
Zak666Williams posted Fri, 04 January 2008 at 2:57 PM
this water tutorial is awsome, but how do i get a Open Ocean with no ground?
when i preview it just has a wite section at the bottom and when i delete the ground i just get a blue screen
(same thing happends when i try to change the ocean matirial.)
Thanks.
Valerie-Ducom posted Fri, 04 January 2008 at 2:57 PM
Valerie-Ducom posted Fri, 04 January 2008 at 3:11 PM
Ah.. and you don't have Espite, but Vue 6 Esprit ... We have 5 vue6 possibles :### Vue 6 Easel – the easy way to 3D
Vue 6 Esprit – the artist’s choice
Vue 6 Pro Studio – for the advanced artist
Vue 6 Infinite – the stand-alone solution
Vue 6 xStream – the integrated solution
Zak666Williams posted Fri, 04 January 2008 at 3:19 PM
this is what i came up with although i don't like it that much.
It's to dull and not clean enough and isnot very real.
Valerie-Ducom posted Fri, 04 January 2008 at 3:29 PM
The better real scene is to make a photograph.
Vue 6 is a program for to creat a virtual scene, but if you want to have a realism in your image, with the textures, bumps and function, you can have some very realist image, but still virtual. See in the gallerie general here and I'm sure you will have a lot surprise...
Arraxxon posted Fri, 04 January 2008 at 4:35 PM
Do you have the Vue sample scenes installed ?
There should be at least two underwater scenes for training and check, how it's set up.
You could even use the atmospheres or whatever as base starts for your own scenes to be changed as you like it.
And there is, too, a scene with a ocean wavy surface, produced with the function editor, could be used as a base water surface to hover above your scenery and to send light through it's surface for water light beam effects or whatever...
silverblade33 posted Sat, 05 January 2008 at 11:44 AM
Folk use HAZE or fog to simulate underwater conditions ;)
to give "caustics" you can use a light gel applied to a spot light.
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
MNArtist posted Sat, 05 January 2008 at 11:50 PM
Hey Gang - A little off-topic here, but I'm having a sudden issue with Vue6E, specifically around underwater scenes, and am wondering if anyone has run into this. My main camera is disappearing from the scene and vue won't allow me to add another one. This is happening regardless of whether I build the scene, then add the water, or whether I start the camera below or above water level. Has anyone ever run into a disappearing camera before?
Peggy_Walters posted Sun, 06 January 2008 at 11:50 AM
Strange - check your options setting (File, Options) and look at the display tab. Maybe uncheck both the stop camera to go below clipping plane and clip objects below clipping plane. Maybe the first is unchecked, but the second one is not - so once camera goes below the water is not displayed...
It should always still be on the browser list though. If it is disappearing from there - that would be a tech support ticket.
