Debbie M. opened this issue on Apr 14, 2001 ยท 28 posts
Debbie M. posted Sat, 14 April 2001 at 10:37 AM
Has anyone else tried to texture this chair? I downloaded the mesh map, and painted a texture that I wanted to render on it.... now I have the texture set for all elements of the chair, but it wont render with the texture applied shrug It still renders the object color. I've never had this happen to me, does anyone else know what is causing this? Thanks! Deb
Debbie M.
Kevin posted Sat, 14 April 2001 at 11:02 AM
You set the color to white and it won't reset?
steveshanks posted Sat, 14 April 2001 at 11:15 AM
Marque posted Sat, 14 April 2001 at 11:39 AM
Steve, can you please do a map an object? I tried and I just don't have the knack of spreading it out so it's easy to texture. Thanks, Marque
steveshanks posted Sat, 14 April 2001 at 11:47 AM
i just opened it and went edit/ new uvmap/ box and hit ok then exported, (i didn't change any settings when i did this or saved it) then just did a texture fill in pic publisher and it worked fine :o)...ones like this are rare though LOL.........Steve
Lovely Lady posted Sat, 14 April 2001 at 12:00 PM
I emailed Daz about that and they fixed it so the download has the object mapped now. So a re-download and install will fix the problem.
Marque posted Sat, 14 April 2001 at 12:03 PM
Thank you Lovely Lady! Marque
Marque posted Sat, 14 April 2001 at 12:11 PM
Well, I guess I'm too caffiene deprived cause I downloaded and re-installed it and it's not working. I'll play with it later. Happy Easter! Marque
Lovely Lady posted Sat, 14 April 2001 at 12:27 PM
Before I re-installed I deleted the unmapped object file, maybe that is what did the trick? Perhaps it did not overwrite the object for you?
Marque posted Sat, 14 April 2001 at 12:36 PM
You're probably right, but first....coffeeeeee! lol Thanks, Marque
Marque posted Sat, 14 April 2001 at 12:40 PM
Oh Lovely Lady! It worked .. thank you! Marque is sending you a hot cafe mocha Ack, won't go in the A-drive! Marque
Dizzie posted Sat, 14 April 2001 at 1:18 PM
Dizzie posted Sat, 14 April 2001 at 1:22 PM
Lovely Lady posted Sat, 14 April 2001 at 1:22 PM
Lovely Lady posted Sat, 14 April 2001 at 1:25 PM
It does seem to stretch the fabric in places. I guess a remap is in order, oh well. Geez, what does one expect for free these days..LOL
steveshanks posted Sat, 14 April 2001 at 1:50 PM
just do as i did above that will fix the mapping :o)...Steve
Dizzie posted Sat, 14 April 2001 at 3:29 PM
steveshanks posted Sat, 14 April 2001 at 3:37 PM
Dizzie posted Sat, 14 April 2001 at 3:57 PM
Debbie M. posted Sat, 14 April 2001 at 4:02 PM
That works great Steve!! Thanks so much for your help :) Deb
Debbie M.
Debbie M. posted Sat, 14 April 2001 at 4:04 PM
Hang on Steve... now when I save over the original obj.... the dial for the morphing is gone?? Did I do something wrong there? Deb
Debbie M.
steveshanks posted Sat, 14 April 2001 at 4:06 PM
Glad to help Dizzie :o)...Steve
steveshanks posted Sat, 14 April 2001 at 4:14 PM
we must have posted at the same time there :o)...........thats weird coz it shouldn't make any difference (mines ok) the morph should be imbedded into the pp2 file....tell you what install the chair again but to a difrent directory and get the pp2 file out and replace the old one with it that should fix it ......Steve
Debbie M. posted Sat, 14 April 2001 at 4:21 PM
I've gotta be doing something wrong Steve, because that didn't work for me either. Deb
Debbie M.
Marque posted Sat, 14 April 2001 at 4:23 PM
Lovely Lady, You're a nurse? I don't have mochas much myself and I hate flavored coffee. I worked noc shift for years in the E.R. and always brought my own thermos's of Foldgers. lol People would say, is that special coffee? And I would say, no, just good coffee. Steve, I don't understand how it's working, do I need to download another template? Marque
steveshanks posted Sat, 14 April 2001 at 4:38 PM
no Marque just load up the obj in uvmapper and imediately go edit/new uvmap/box and leaving all the settings at default hit OK then go file/save model and again just click ok and don't change the settings.....then go file/load model and when the window pops up change the "files of type" to read all files and delete the rsr .....finally go file save texture map and use that to paint on..i'm not sure why the morph dials are disapearing BUT applying the morphs will stretch the texture anyway so it may be a good idea to create various styles then export as objs remap as above and import to create a few props instead of one morphing one.....one thing though if you turn it into a sofa when you remap it then go edit select all and drag the template till it is in proportion to the shape of the sofa to prevent stretching.......Steve
Marque posted Sat, 14 April 2001 at 5:01 PM
Thanks Steve! Appreciate you having patience with me on this. I've had a stupid low-grade migraine for two weeks now and it makes it tough to think things out. 8^) Marque
Debbie M. posted Sat, 14 April 2001 at 5:15 PM
YAHHOOOOOO, thanks Steve, and Diz so much for your help!! It was ONLY a case of having to download the new one at Daz... now all is working fine on the homefront :) Thanks again!! Deb
Debbie M.
