Subject: My first animation
Jestertjuuh opened this issue on Jan 06, 2008 · 5 posts
Jestertjuuh posted Sun, 06 January 2008 at 3:44 PM
Hello folks,
Well as usual I was working on my new girl and started to wonder off and ended in the animation section.
So fidled around with all of the stuff in there (and darn, thats a lot =))
And this is the end result.
Well its raw material and unrendered.
It also contains a few glitches, so I wont expect that Pixar will call next week ;-)
But it was fun to do and something to look further into in the future.
I spiced it a litle up in moviemaker and found in the outcome that the size is not corect..urg.
Oh well, its just a test  =)
No idea where to place it, so here is the link to youtube.
[http://nl.youtube.com/watch?v=-z9hWgYa8es
](http://nl.youtube.com/watch?v=-z9hWgYa8es)
I am not a complete idiot, some parts are missing :)
To go to my home page, click the banner below.
Check my freebies on a regular base, click the banner below.
lesbentley posted Mon, 07 January 2008 at 6:06 PM
That's a pretty good animatrion, especially for a first post. Did you make the motion yourself, or is it from a BVH file? One tip, a camera is showing in the center of the scene, you would not get that in a rendered image, but even in preview, setting the camera to invisible in its Properties tab should hide it.
Jestertjuuh posted Tue, 08 January 2008 at 2:12 AM
Thanks Lesbentley,
I made the motions myself, did take some time but luckely Poser fill's in some gaps.
E.O.W. you give her a start pose and a end pose around 15 frames later and Poser fills in the motion inbetween.
You still need to rework it a bit to smoothen it out and remove any overshoot and undershoot.
And some complex movement need to be done step by step.
The camera is another story,
I was not able to select it, its eather a bug or my lack in knowledge.
So I was not able to get it out of sight =(
The clip is around 400 frames, I did put it on render and wend to bed, the next morning it was not even halfway =)
Used lowest settings, so I gues my comp is getting to old for this.
All in all it was just a fun experiment to try out animation.
And probably something to look into later and make a better animation.
Dale B posted Tue, 08 January 2008 at 5:00 AM
Not too bad at all! Welcome to the wonderful world of keyframing......!
UVDan posted Thu, 10 January 2008 at 10:06 AM Forum Moderator
Nice job.  I was hoping it was going to be a naked big breasted Vicky on a roller coaster animation.
Free men do not ask permission to bear arms!!
