Schunken opened this issue on Jan 07, 2008 · 5 posts
Schunken posted Mon, 07 January 2008 at 3:13 PM
when I render in Poser in the Firefly engines at Final Settings i often have 1-3 little black lines in the final rendering.....see above example....
they can be vertically...and horizontally
Anybody know why this happen and how to avoid? It drives me mad render a Scene 20 minutes and than get this :(
Andreas
chris1972 posted Mon, 07 January 2008 at 3:59 PM
I have the same issue. I have noticed while watching the image render, those black lines appear at the edges of the little render box ( I'm not sure if thats what you call it but the image renders one little box at a time) maybe trying a smaller bucket size (under manual render settings max bucket size) I don't know if that will fix the problem, I usually use the healing brush on them in photoshop.
I will be curious to see what others say, thanks for the post.
Chris
stewer posted Mon, 07 January 2008 at 4:22 PM
Try setting small displacement bounds, like 0.2 or so in the render settings.
linkdink posted Mon, 07 January 2008 at 4:26 PM
Try setting small displacement bounds, like 0.2 or so in the render settings.<
Yes, this fixes flat surfaces for me, like a square background. I don't usually get those artifacts on curved surfaces, like V3 or clothing.
Schunken posted Tue, 08 January 2008 at 8:58 AM
Thanks much!
I will try this!
Andreas
