saus69 opened this issue on Jan 07, 2008 · 13 posts
saus69 posted Mon, 07 January 2008 at 7:33 PM
I can't find any in the freestuff section. Was wondering if there are any modern/post-vietnam figher plane helmets for the v4 model.
mrsparky posted Mon, 07 January 2008 at 9:05 PM
Attached Link: http://www.vanishingpoint.biz/productdetail.asp?productID=115
Not free and not originally for V4 - but try the link above.Just use the parameter dials to make it fit and then parent to the head.
Theres also another model on sale here - but I can't seem to find it.
mhscspo posted Mon, 07 January 2008 at 9:20 PM
Attached Link: http://rapidshare.com/files/82115526/flighthelmet.zip
> Quote - I can't find any in the freestuff section. Was wondering if there are any modern/post-vietnam figher plane helmets for the v4 model.Try this and see if it works..
saus69 posted Tue, 08 January 2008 at 4:37 AM
Can't use rapidshare... is it hosted anywhere else?
mhscspo posted Tue, 08 January 2008 at 10:10 AM
Quote - > Quote - Can't use rapidshare... is it hosted anywhere else?
Try this one:
http://megaupload.com/?d=RLU281BT
pakled posted Tue, 08 January 2008 at 8:28 PM
not exactly fighter helmets, but there's some Sci-Fi helmets for the earlier Vickies at Runtime DNA (I think they're Maveris' helmets, but they could do in a pinch). In the freestuff...a ways back though...
DarkStarBurning posted Wed, 09 January 2008 at 4:17 AM
Attached Link: http://www.runtimedna.com/mod/bcs/index.php?ViewProduct=3047
:)saus69 posted Thu, 10 January 2008 at 5:03 AM
Sorry, really cannot access megaupload. Can someone mail me that file at sausage at gmail.com? Thanks.
mhscspo posted Thu, 10 January 2008 at 7:58 AM
Quote - Sorry, really cannot access megaupload. Can someone mail me that file at sausage at gmail.com? Thanks.
Ok
saus69 posted Sun, 13 January 2008 at 7:25 PM
Just tried adding a custom diffuse texture to the helmet but I can't get it to work. I drew on the unwrapped map but when I use the material room to add this jpg as a diffuse texture, it comes out smaller than the helmet model.
What am I doing wrong?
mhscspo posted Sun, 13 January 2008 at 9:59 PM
Quote - Just tried adding a custom diffuse texture to the helmet but I can't get it to work. I drew on the unwrapped map but when I use the material room to add this jpg as a diffuse texture, it comes out smaller than the helmet model.
Make sure that your copy .jpg is the exact same size as the original
saus69 posted Sun, 13 January 2008 at 10:11 PM
It is... I was actually using the supplied template. Is there any way to stretch the map from within poser?
mhscspo posted Sun, 13 January 2008 at 10:31 PM
Quote - It is... I was actually using the supplied template. Is there any way to stretch the map from within poser?
I normally do everything in photo shop and then place things by way of the material room.
