Forum: Bryce
Subject: Bryce fails to open at all! Help!?
FranOnTheEdge opened this issue on Jan 10, 2008 · 10 posts
FranOnTheEdge posted Thu, 10 January 2008 at 8:36 AM
On a PC with win XP version 2002 service pack 2, Intel Pentium 4 CPU 3.40GHz
2.00 GB of Ram with an NVIDIA GeForce Go 6800
Both Bryce 6.1 and Bryce 5.5 fail to open.
Bryce6 version is 6.1.12.6.
Error message as in the pic
(only thing I've done since yesterday evening when it was working just fine is update iTunes and Quicktime)  But there was also a Windows update, recently, either last night or the night before.
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
ThunderStone posted Thu, 10 January 2008 at 11:00 AM
So glad I didn't do the window update... I have noticed that everytime there's an update for windows service pack etc. something goes bonkers in some application... You might have to download and re-install the C++ library.... Are u running any Microsoft Office Suite application in the background?
Like outlook or words or something like that? That could be the culprit... I had the same problem when I first started using Bryce 5.5. I don't know what happened but after re-installing the C++library and not opening up Words or Outlook before Bryce, I'm ok...
You also might want to check Microsoft site for further explanation of your error code.
OS: Windows 11 64-bit
Bryce: Bryce Pro 7.1.074
Renderer: Superfly, Firefly
9/11/2001: Never forget...
dan whiteside posted Thu, 10 January 2008 at 1:11 PM
Fran - no big deal but you might want to repost your image without your serial number ;-) As to your question have you installed a new version of DAZ Studio?
TheBryster posted Thu, 10 January 2008 at 1:15 PM Forum Moderator
One word. HOUSEKEEPING.
Empty Temp folder
Empty Temp Internet folder
Clear out History
Clear Recently opened
Defrag.
Shutdown
Re-boot.
electroglyph posted Thu, 10 January 2008 at 3:00 PM
drwtsn32.exe is the doctor watson tool for windows. That's the thingy that gathers information from a crash then pops up the window that asks "would you like to submit a report?" The number 0xc00000005 means the device failed to hook up to the systray. "It didn't initialize and create a control window."
Press control alt delete.
Click on the task Manager button.
When the window pops up click on the applications tab.
look under tasks and see if a copy of Bryce exe is already running. If it is click it and press the end task button.
Look to see if Bryce disappears from the tasks and try to restart Bryce.
Analog-X64 posted Thu, 10 January 2008 at 3:22 PM
always try a re-boot if you get this type of error.. Since Windows v1.0  it has always had Memory Issues, especialy when opening and closing apps...
Almost always some software will close without its resources being freed back to the windows, and an crash follows.
bobbystahr posted Thu, 10 January 2008 at 3:23 PM
Fran...I took the liberty of deleting your image as it contained your name and serial number and as this is an open forum this is a bad place for that.
Re: non starting...well I got the update and no problems here so I would recommend trying the above mentioned steps by Bryster and electroglyph.. ...
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
AnnieD posted Thu, 10 January 2008 at 5:21 PM
I also got the update..and Bryce works fine.
It seems that Fran was having some trouble with installing a new version of DS....but not sure.
“For those who believe, no proof is necessary. For those who don't believe, no proof is possible.”
[Stuart Chase]
skiwillgee posted Thu, 10 January 2008 at 7:16 PM
Do a system restore to a date before the upgrades.
Then re-install upgrades one at a time.  At least you may narrow down to the culprit.  I don't let Windows auto upgrade.  I just get the notification of an upgrade available then I install one at a time.
FranOnTheEdge posted Fri, 11 January 2008 at 6:55 PM
Thanks Bobby - I hadn't even realised.  Phew!
I think (apart from all the other problems like trying to get Daz sorted etc) I think what's killed the laptop is a bad install of quicktime.
I thought we'd cured the laptop and was copying files from Prog files/DAZ/bryce - not the presets I always keep those up-to-date every so often anyway - I was just making sure, copying scene files etc, even though I think they arrive when you install afresh anyway.... and the laptop bluescreened on me - again.
I store Bryce scene files (my own) on an external drive anyway so they are safe... for now.
I have now got the PC working with it's cool, fresh, new, hard-drive and I'm determindly not looking at the laptop.
Just ordered a new hard drive for the laptop, so when I go home Husband can fit & install that and then try to see if he can save any info from the 'sickypoo' drive.
sigh...
Like I said in another desperate thread not so long ago - back up - often!
Fran's Freestuff
