RedPhantom opened this issue on Jan 13, 2008 · 5 posts
RedPhantom posted Sun, 13 January 2008 at 9:02 PM Site Admin
ockham posted Sun, 13 January 2008 at 9:58 PM
Are you sure that all the material settings are the same? Check
especially the color, value and size in percent of the highlight (specular).
RedPhantom posted Sun, 13 January 2008 at 10:33 PM Site Admin
Here is a screen shot of the material I'm using incase that helps. I'm not real good with nodes and all so maybe what i'm doing is wrong.
nruddock posted Mon, 14 January 2008 at 4:04 AM
As you've got a "V" node in the network, then the colour is going to vary according to how the UV mapping is laid out.
Try seeing what happens when you remove it.
If you could say what your thinking that node is there for, it should be possible to offer an alternative.
RedPhantom posted Mon, 14 January 2008 at 3:46 PM Site Admin
Honestly, I don't know why the v is there. I was editing a material that I had on the computer called waqsman. I guess It's not that big of a deal. I can find another material to use.
