DocMatter opened this issue on Jan 18, 2008 · 5 posts
DocMatter posted Fri, 18 January 2008 at 10:51 AM
pdblake posted Fri, 18 January 2008 at 11:01 AM
Attached Link: Linky
Maybe you need to stand on a box?Seriously a quick google tells me that you need elevated priviledges. I presume that means you need to log on with administrator priviledges to install.
svdl posted Fri, 18 January 2008 at 12:12 PM
You could also browse the CD, right-click Setup.exe in the root folder of the CD and choose "Run as administrator" (or whatever it may be called in Vista. I don't run Vista).
thefixer posted Fri, 18 January 2008 at 3:23 PM
Running as admin should fix that because Vista is telling you you don't have sufficient privileges to do what you're trying to do!
There are ways of switching off the UAC depending on what version of Vista you're running, which is it??
Injustice will be avenged.
Cofiwch Dryweryn.
DocMatter posted Fri, 18 January 2008 at 4:36 PM
I'm running Vista Ultimate. I already figured out svdl's method accidentally and its all installed okay.
Thanks for everyone's help!
