Subject: Collapsing animation layers??
ikercito opened this issue on Jan 23, 2008 ยท 6 posts
ikercito posted Wed, 23 January 2008 at 7:05 PM
Hi all, I've just finished an animation for my character (nothing fancy, but I've spent some time and finally i like it). Basically I created a base layer with a walk, then corrected/exagerated some of the moves thru another layer on top, and then added another layer with some more stuff...
When the pose is saved (as an animation) to the library it looks like it only saves the selected layer. I only get the corrections saved if I'm in layer 1, or only the walk if I'm in base layer... Is it possible to bake/merge/collapse the 3 layers into one, so the whole animation gets saved to the library?
My goal is to render all the stuff in Carrara, and it turns out that when importing the whole scene the animation doesn't quite work as is supposed to... Not even when importing into DAZstudio! Only way I can think of, is collapsing the layers and importing the whole animation this way into Carrara. Any help??
Thanks!
ikercito posted Fri, 25 January 2008 at 7:30 AM
no help? no python or method to do this?
Thanks again...!
kuroyume0161 posted Fri, 25 January 2008 at 8:41 AM
See this thread for starters:
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3108805&ebot_calc_page#message_3108805
 -- Bjarne Stroustrup
markschum posted Fri, 25 January 2008 at 12:09 PM
You can save it as an animated pose , and when reloading it will prompt you to collapse all layers .
This was asked before .
ikercito posted Fri, 25 January 2008 at 1:26 PM
Sorry guys, didn't mean to bump the thread. Searched for it, but couldn't find anything... thanks for the info!
markschum posted Fri, 25 January 2008 at 5:40 PM
no problem , if ya cant find an answer then ask .
There doesnt seem to be an easy way to do it in python , sorry .
