mdiramali opened this issue on Jan 25, 2008 · 9 posts
mdiramali posted Fri, 25 January 2008 at 5:31 AM
Does poser 6 or 7 work with windows vista?
Stepdad posted Fri, 25 January 2008 at 5:44 AM
I know for certain 7 does, in fact it's been more stable for me under Vista than it was under XP. I can't imagine why 6 wouldn't, in fact I haven't had trouble with any of the apps I used to run under XP with Vista.
Now, a word of caution, not everyone has had such luck with Vista, it can be a bit finicky about the hardware your using and if you don't at meet or exceed it's minimum system requirements you might want to reconsider installing it.
Also as with any windows based operating system, your best bet is to wipe a partition and do a clean install, trying to install over a different version of windows all too often results in problems, particularly in the stability area.
So if you are going to give Vista a look you'll want to backup your files and do a clean install for best results. Personally I'm very happy with it, but mileage does vary - a lot of other folks were not happy with it when they installed it.
Hope that helps..
Stepdad
pakled posted Fri, 25 January 2008 at 6:54 AM
syntax error: 'Vista' and 'working' used in same sentance. Redo from start, and call Dr. Watson in the morning...;)
thefixer posted Fri, 25 January 2008 at 8:42 AM
Yes it does, I'm running Poser 6 and 7 on Vista Ultimate 64, no issues!
Injustice will be avenged.
Cofiwch Dryweryn.
mandy2uk posted Fri, 25 January 2008 at 8:53 AM
Quote - Does poser 6 or 7 work with windows vista?
I'm running Vista and Poser 7 is working for me without any problems!
Ondoval posted Fri, 25 January 2008 at 11:14 AM
poser 7 + Vista 32 (3Go Ram)
Very stable for me.
For art to exist, for any sort of aesthetic
activity to exist, a certain physiological precondition is
indispensable: intoxication.
We have art in order not to die of the
truth.
Friedrich Nietzsche
Santel posted Fri, 25 January 2008 at 11:36 AM
Both 6 & 7 fine for me as well...
silverblade33 posted Fri, 25 January 2008 at 12:53 PM
P6 works great on my Vista 64 :) loads lot faster
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
Cage posted Sat, 26 January 2008 at 12:04 AM
Poser 5 and Poser 7 are both handling well for me on Vista. I wish I could say that about all of my other frequent use applications....
Cage can be an opinionated jerk who posts without thinking. He apologizes for this. He's honestly not trying to be a turkeyhead.
Cage had some freebies, compatible with Poser 11 and below. His Python scripts were saved at archive.org, along with the rest of the Morphography site, where they were hosted.
