Subject: How to create a narrow spotlight beam??
hamiltonpl opened this issue on Jan 26, 2008 · 11 posts
hamiltonpl posted Sat, 26 January 2008 at 4:05 PM
I've been experimenting with volumetric lighting so that I get a good beam from a prop flashlight.  However the angle is too wide. I can't seem to find the right dials or setting to make this  a NARROW beam. Does anyone know how to do this?
Windows 10 - Poser Pro 2012 - 64Bit - 24GB RAM - 4 x 3.40 GHZ processor
Acadia posted Sat, 26 January 2008 at 4:57 PM
For a spotlight I think you need to fiddle with the "start" and "end" dials.  Here is a thread that explains how that works.
http://www.runtimedna.com/mod/forum/messages.php?forum_id=95&ShowMessage=346553
FrankT posted Sat, 26 January 2008 at 5:02 PM
angle start and angle end are the two you are wanting.  Angle End specifically - smaller the number, narrower the beam
My Freebies
Buy stuff on RedBubble
hamiltonpl posted Sat, 26 January 2008 at 5:46 PM
okay thanks. To get the beam to come out of the prop flashlight I am having to place the actual spot pretty far back so tha the width of the spot matchs the diameter of the flashlight end. I wish than intial angle could be made wider - as is I have a light well behind a prop that does not cast shadows...is there and eaier way that I am not thinking of here?
DarkEdge posted Sat, 26 January 2008 at 5:58 PM
Dist start will affect the starting point beam width...is that what you need?
hamiltonpl posted Sat, 26 January 2008 at 6:13 PM
Maybe......what value would you use to have the width be wider at the beginning of the beam? Also, is there a limit to the number of spotlights within a scene that can render volumetrice effects? I have TWO.  One will render and the other will not......
DarkEdge posted Sat, 26 January 2008 at 6:28 PM
Quote - Maybe......what value would you use to have the width be wider at the beginning of the beam?
Angle Start 10 (example)
Angle End 3
Wide beam beginning and narrowing at the end. 😉
lesbentley posted Sat, 26 January 2008 at 7:13 PM
Quote - Dist start will affect the starting point beam width...is that what you need?
To the best of my knowledge, the above quote is not correct. As I understand it, 'Dist Start' will NOT affect the starting point beam width. Dist Start will only work when Dist End is used, Dist End sets sets the distance at which the light will cease to have any effect, Dist Start sets the distance at which the light intensity will start to fall off.
DarkEdge posted Sat, 26 January 2008 at 7:52 PM
Yes, I misspoke. Hence; my follow up thread above.
Let's just keep this dirty little secret (mistake) between ourselves shall we? :lol:
geep posted Sun, 27 January 2008 at 12:38 PM
Attached Link: http://drgeep.com/NPU/admin/00/001/tothetunnel.htm
Something like this?
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Sun, 27 January 2008 at 12:44 PM
Attached Link: Poser University - 2nd Floor Directory
*(click the image to be able to read it) (click the link above the image to go to the 2nd Floor Directory at NPU)*
Also, you might find some useful info in one of these classes.
See rooms S201, 202, 203, and 204.
Click the link (above the image) and then click on the class name to "enter" a class.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
