Subject: Diabolic Hybrid?
jcrous opened this issue on Jan 28, 2008 · 14 posts
jcrous posted Mon, 28 January 2008 at 11:31 AM
Hi,
I am currently using mostly A3 and V4 as my females and M3 as my male characters.
You can not buy everything you see and want, so you have to compromise.
I want to know if I can hybridise a head of a V4 figure onto a A3 body and save it as a new character morph.
I have seen something about this topic in tutorial format somewhere, but I have not taken notice and now I can not find it. I am not even sure if it is what I think it was?
Regards
Johan
Regards
Johan
nyguy posted Mon, 28 January 2008 at 11:55 AM
in issue 99 of 3d world magizine they have a great tutorial on what you are trying to do. Try searching their site.
Poserverse The New Home for NYGUY's Freebies
Kalypso posted Mon, 28 January 2008 at 2:58 PM Site Admin
Crescent has a couple of tutorials on "frankensteining" figures here:
http://www.ebonshire.net/tut-posa/index.php
I think they may require you to model a neck but I skip that part and use the neck from the figure whose body I'm using since I am not doing animations and can postwork any problem areas.
Hope this helps.
bopperthijs posted Mon, 28 January 2008 at 7:16 PM
If money is an issue you should download Appolo maximus as a male character, it's free model with several free textures and one of the best poser-models being around these days!
Here's the link:
www.antonkisieldesigns.com/~akfiles/htmlpages/ApolloMaximusFree3dhumanfigure.htm
regards,
Bopperthijs
-How can you improve things when you don't make mistakes?
ThrommArcadia posted Tue, 29 January 2008 at 3:01 AM
If outfits is the concern (as it often is) what you might want to do is get a plugin or software for converting clothing from one character to another.
Here are some of the popular options:
Wardrobe Wizard
CrossDresser
Clothes Converter
Each has it's loyal following and I have not used all three so I could not tell you the main differences.  I will say that the power to make you A3 outfit fit on V4 might change your world.
Hope this helps.  If I completely misinterpreted your needs, then ignore me.
estherau posted Tue, 29 January 2008 at 4:18 AM
sometimes what's needed is the poses not the clothes, so converting clothing doesn't solve everything. frankensteiing is also good. Love esther
MY ONLINE COMIC IS NOW LIVE
rofocale posted Tue, 29 January 2008 at 6:17 PM
Attached Link: http://www.ebonshire.net/tut-posa/poptop-a1.php
...or you can follow this great and simple tutorial! The only thing is that V4´s head and neck differ a bit from the other ones, but postwork or a touch of magnets (or both) will do the thing :)) Trust me...it works, almost every character in my renderings are hybrids! Check out my gallery and see for yourself.
estherau posted Wed, 30 January 2008 at 6:12 AM
I once tried that tutorial to put V4 head on /v3, but unfortunately after getting halfway, the instructions weren't good enough for me because V4 has extra parts in her mouth and tonuge so I couldn't hack the Cr2.  hacking up a fur ball would have been easier.
Love esther
PS good tut for transplanting heads from one mil figure to another though.
Kalypso posted Wed, 30 January 2008 at 8:21 AM Site Admin
Well if you're swapping between unimesh figures you can always just use Kamilche's script Shapeshifter found at PhilC's site.
http://www.philc.net/freestuff.htm
rofocale posted Wed, 30 January 2008 at 11:25 AM
...strange, I had no problem with that. I just did as I had done with the Mill 3 and 2 hybrids.
Just followed the tut!
estherau posted Wed, 30 January 2008 at 5:23 PM
I should look at that tut again then, but I already tried it twice before. Love esther
rofocale posted Thu, 31 January 2008 at 1:57 AM
estherau
Export the tounge and teeth by following the same procedure as for the head and eyes(V4).
estherau posted Thu, 31 January 2008 at 8:34 AM
I did export them, but I was stuck when it came to incoorporating the code into the Cr2 Love esther
rofocale posted Thu, 31 January 2008 at 9:47 AM
Better luck this time :)
