smalll opened this issue on Feb 01, 2008 · 8 posts
smalll posted Fri, 01 February 2008 at 9:12 PM
Attached Link: http://www.bokgi.net/test/001.jpg
I want to make piston. You can download my file. [www.bokgi.net/test/Runtime.zip](http://www.bokgi.net/test/Runtime.zip) There is one character. It has 4 structure. down, up, big, small I want big face to small. But, I can't. Can you help me? How can I make it?MegaJax posted Fri, 01 February 2008 at 9:35 PM
I beleave Dr Geep has tutorial on how to do this on his Poser University site.
smalll posted Fri, 01 February 2008 at 9:39 PM
yes. his tutorial is like below image.
But, I want to learn more.
www.bokgi.net/test/002.gif
ockham posted Sat, 02 February 2008 at 1:12 AM
The solution is Point-At.
Select 'small', use the Poser menu Object / Point At.
This will give you a hierarchy window; in this window, select 'big'.
Then do the opposite:
Select 'big': use Object / Point-At. In the window, select 'small'.
After this step, the piston and cylinder will always stay aligned.
smalll posted Sat, 02 February 2008 at 1:16 AM
It work!
Success!
Wonderful!
Thank you.
It's amazing!
Thank you very much!
ockham posted Sat, 02 February 2008 at 1:20 AM
pakled posted Sat, 02 February 2008 at 2:27 PM
I use it for eye -point at- main camera. Then no matter where you look at the picture, the eyes follow you...;)
smalll posted Sun, 03 February 2008 at 2:00 AM
Thank you.
You are so kind.
