Forum: Photoshop
Subject: help with text conforming to an object
paragon5 opened this issue on Feb 03, 2008 · 2 posts
paragon5 posted Sun, 03 February 2008 at 11:25 PM
Hi all, I am having a problem trying to fix a very simple project.  All I have to do is make an oval and then add text.  Which must conform to the inside of the oval.  I'm currently drawing a blank.  Anyone have any questions or suggestions?  I am using PS cs2.  I've included an example.  Thanks in advance, William
prixat posted Mon, 04 February 2008 at 5:34 AM
Hi William I don't know of an automatic or semi-automatic method like I would have in CorelDraw or Illustrator. But if you get the oval done you can match the text to it 'manually' quite easily. In the text layer, Right-click, Free Transform and use 'Warp' mode with the 'Bulge' warp. You can toggle back and forth between Free transform and Warp transform as necessary (and the text stays as text!).
regards
prixat
