Bubbels opened this issue on Feb 08, 2008 · 6 posts
Bubbels posted Fri, 08 February 2008 at 8:03 AM
After using daz studio for a while I thought it was time for Poser 7. So I installed Poser, started playing with it, and decided to uninstall Daz Studio. But after uninstalling Daz Studio, Poser started giving an error. ASI32_12.dll is missing. So I thought the problem would be the uninstalation of Daz Studio. So I re-installed Daz Studio , but the problem isn't solved with this. I still get this error, and I'm getting really frustrated, because I really don't know enough about computers to know what this error means. Please, can someone explain what went wrong here? And more important; how to fix it? Thank you!
ockham posted Fri, 08 February 2008 at 8:32 AM
Sounds like the DAZ uninstaller decided that the copy of ASI32_12.dll in
Poser's folder was a "shared DLL", and removed it.
If you've backed up your Poser installation on a CD or something, you
can just copy the DLL from the backup into the same directory as Poser.exe.
Otherwise, you'll probably have to reinstall Poser 7.
Bubbels posted Fri, 08 February 2008 at 8:51 AM
I already did. 3 Times! I really don't understand why I can't find this file anywhere. And why re-installing Poser won't fix the problem.
ockham posted Fri, 08 February 2008 at 9:33 AM
Try re-installing into a non-default location like c:poser7 instead of the default
folder. If that works, you can either move all your content into the new location,
or just set up the old location as a separate runtime.
For some reason this one DLL file causes all sorts of odd problems
with installation; seems like the installers think it's present when it isn't,
and vice versa.
Bubbels posted Fri, 08 February 2008 at 10:44 AM
Thanks! I did what you said (other location) and everything works fine now! Thank you thank you thank you!
ockham posted Fri, 08 February 2008 at 1:29 PM
Yay! It's nice to see a problem solved!
