Tyger_purr opened this issue on Feb 08, 2008 · 10 posts
Tyger_purr posted Fri, 08 February 2008 at 11:29 AM
I have a product but the textures at 3000 X something is not clear enough for my needs
Is there a product that will allow closeups like this with clear textures.
I am trying to create illustrations for a story, so background images won't be enough, i need something i can get the same planet from diffrent angles.
budget is kinda tight so i have to keep it under $100 US.
My Homepage - Free stuff and Galleries
Lucifer_The_Dark posted Fri, 08 February 2008 at 11:40 AM
Attached Link: Genetica
Genetica might fit the bill, slightly over your $100 budget though.Windows 7 64Bit
Poser Pro 2010 SR1
SamTherapy posted Fri, 08 February 2008 at 11:55 AM
Attached Link: http://www.shatters.net/celestia/
How about Celestia? It's free so the price is right.Coppula eam se non posit acceptera jocularum.
pakled posted Fri, 08 February 2008 at 4:52 PM
Mojoworld would do the same (using moons) but it's over the $100 limit. There's a trick (tutorial) in Terragen (planetside, and free for the sub-V2 version) that makes a 'low orbit', which is a lot under $100. Bryce (5.5 should still be free, should be a link in the Bryce forum) can do planets of a certain size, with the right material.
If you have Photoshop, Flaming Pear has some planetary filters, or skins, or whatever they're called...;)
silverblade33 posted Fri, 08 February 2008 at 7:39 PM
Problem with textures for a close approach, is they need to be impossibly large....16,000x8,000 and larger...as that's the WHOLE sphere.
OR, you take a sphere, cut out a square patch of it, so you have curvature, UV map it, fit a smaller, square texture to it ;) (figured that one out for meself, hehe).
OR you can warp the Field of View of a camera, so a flat horizon, curves. This can give a false effect of flat terrain = planet curve.
Tutorial on that inside Vue.
FLaming Pear "Lunar Cell" does planet textures, to look great though they do need work.
Very good tutorial on this on www.scifi-meshes.com
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
RubiconDigital posted Sat, 09 February 2008 at 1:24 AM
Tyger_purr, I could most likely produce textures for you that would not pixellate regardless of final render size or camera proximity. It depends how much time you have. Send me a site mail if you're interested.
ghonma posted Sat, 09 February 2008 at 6:29 AM
ghonma posted Sat, 09 February 2008 at 6:35 AM
SamTherapy posted Sat, 09 February 2008 at 7:02 AM
Nice effect there, ghonma. A higher res globe would be better for closeups, though. You can see the poly edges on the pic above.
ghonma posted Sat, 09 February 2008 at 7:56 AM
Good eye there SamTherapy :p
Yeah i was being lazy and just imported a default sphere from my modeller. For best quality, a higher rez sphere would look nicer of course.
And the scene file in case anyone wants to play with it (Poser 6)
