heli232 opened this issue on Feb 20, 2008 · 4 posts
heli232 posted Wed, 20 February 2008 at 6:45 AM
I have two pz3 files with one figure.
Is it possible to transfer one figure, with all textures morphs, pose,... to the other pz3, so it shows 2 figures?
Acadia posted Wed, 20 February 2008 at 6:50 AM
Yes, easy way would be to save the figure to your Figure library using the plus + sign at the bottom of the library. When asked about subset, check off all items you want to save with the figure.
Then open the other PZ3 and load the figure. It should load complete.
say." - Ghandi
icprncss2 posted Wed, 20 February 2008 at 7:22 AM
Quote - I have two pz3 files with one figure.
There are a couple of ways to merge scenes in Poser. The simplest is to open one scene, the go to File>Import>Poser Document/Prop. You will get a dialogue box asking you to find the scene. Find the scene and click ok. This will add the second scene to the first. When merging scenes you can get some wieird lighting glitches. Sometimes the first scene's lighting is retained, sometimes it is overwritten by the second's and sometimes they both get loaded and you end up with a mess. If you want to use lighting from one scene, save it as a light set.
Since you only want to add the figure there is another way. Load the scene with the figure, delete everything except the figure. If you don't want the lighting, delete all the lights. Then import the new Poser scene.
heli232 posted Thu, 21 February 2008 at 6:55 AM
Thanks for both answers, that was exactly what I was looking for.
