uncle808us opened this issue on Feb 21, 2008 · 12 posts
uncle808us posted Thu, 21 February 2008 at 7:42 AM
MacBook Pro OSX El Capitan Ver 10.11.6
dan whiteside posted Thu, 21 February 2008 at 7:34 PM
I can't dup this on my MacPro/10.5.1, Bryce 6.1.13.1. Have you looked in the Preset>Trees folder to see if you have the Bamboo.bto file there?
uncle808us posted Fri, 22 February 2008 at 6:27 AM
Yes it is there. I have no idea how to fix this.
dan whiteside posted Fri, 22 February 2008 at 7:48 AM
Do you have B5.5? Might work in that. I use that all the time when I have 6.1 problems.
uncle808us posted Fri, 22 February 2008 at 7:57 AM
No I don't.
FranOnTheEdge posted Fri, 22 February 2008 at 2:53 PM
It's free:
PC Version:
http://www.download.com/Bryce/3000-6677_4-10696716.html?tag=lst-1
Mac Version:
http://www.download.com/Bryce/3000-2187_4-10696718.html?tag=lst-2
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
uncle808us posted Fri, 22 February 2008 at 5:39 PM
Thank you for that info but alas I'm on dial-up and that would take forever to download. I do appreciate you help. Times like these I wish I had high speed.
FranOnTheEdge posted Fri, 22 February 2008 at 7:38 PM
One other alternative, if you have the money for it, is the boxed version from DAZ, but it is $48:97.
Not something I could contemplate, but if you want it and can't download it, that may be the only option...
Measure
your mind's height
bikermouse posted Sat, 23 February 2008 at 4:47 PM
Well you could try a download manager. when I was on dial up they were quite useful as you could stop downloading even turn off or reboot your computer and resume your download later.
If you need a free one do a google search for Fresh Devices (I still use it in case the power goes out or something) . I think the largest file I ever downloaded that way was about 150MB.
uncle808us posted Sat, 23 February 2008 at 5:29 PM
OK thanks for all the help.
electroglyph posted Sun, 24 February 2008 at 2:06 PM
I tried editing this way in windows and it worked without crashing but the result was crap. Try this before you go crazy.
Hold down the Alt button then click on the tree icon. instead of a default tree that you then have to edit you should have a menu pop up with names. You can release the Alt Key once this appears. Scroll down to the Bamboo setting and click. A fairly looking bamboo should appear in your Bryce workspace.
uncle808us posted Sun, 24 February 2008 at 2:49 PM
electroglyph:
It was beatiful worked like a charm... Thank you so very much!
