arrow1 opened this issue on Feb 21, 2008 · 11 posts
arrow1 posted Thu, 21 February 2008 at 4:57 PM
Where do you obtain Lip Sync or txt talk files for V4.2 for Poser 7 talk designer? Or do you have to record them yourself. In talk designer they only offer files for the Poser 7 figures.Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
jonthecelt posted Thu, 21 February 2008 at 5:28 PM
There's a Talk Designer exansion kit, created by Shaders Cafe, available over at Content Paradise. They've just updated it to included visemes for V4.2, although you have to do a little jiggerypokery first to get it to work. Check out their site for further details.
JonTheCelt
arrow1 posted Thu, 21 February 2008 at 6:51 PM
Thank you for your reply.I have already downloaded and installed it.But it does not contain any text or lip sync speaches for V4.2. Cheers
jonthecelt posted Thu, 21 February 2008 at 8:04 PM
When did you download and install it? The V4.2 update wasonly worked out some time this afternoon.
JonTheCelt
arrow1 posted Thu, 21 February 2008 at 8:19 PM
About three hours ago! Perhaps I am barking up the wrong tree.I recieved an email from Content Paradise to say that the Victoria 4.2 issue had been resolved and to go and re download the expansion kit.I have done this and made the necesssary changes in the text editor as suggested. Victoria 4.2 phonemes loaded ok.When I open Talk Designer up in Poser 7 Victoria 4.2 xml appears.But when I try to add .wav files Poser says "This audio format is not reconized by Poser" Also it wants some sort of text file that does not exist.Any help would be apprecuate. Cheers
jonthecelt posted Fri, 22 February 2008 at 2:27 AM
That sounds like it's the Talk Designer itself you're having problems with, rather than V4.2's implementation within it. Have you tried using it with any other charcters?
JonTheCelt
arrow1 posted Fri, 22 February 2008 at 3:48 AM
You are probably right.Mimic works fine.I will have to investigate! Cheers
dennisharoldsen posted Fri, 22 February 2008 at 5:10 AM
i have a copy of poserspeak. it is much easier because you put your dialogue in a text file and it does the rest. there are no audio files involved. you have to purchase an asapi4 voice and there are many good ones available for both male and female and even for other languages. it uses windows text to speech technology and is quite reliable.
there are samples of the output on the website. i don't remember the url but it is easy to find and i can provide it if you want. i also have a sample i generated for testing and can put it on my website. i am currently doing other things but i intend to return to it to make things for my new site.
Touchwood posted Fri, 22 February 2008 at 5:54 AM
Quote - When I open Talk Designer up in Poser 7 Victoria 4.2 xml appears.But when I try to add .wav files Poser says "This audio format is not reconized by Poser" Also it wants some sort of text file that does not exist.Any help would be apprecuate. Cheers
As far as I can remember, the wave file needs to be single channel mono. Try re-saving the sound file in this format. To accompany the wav, you also need to create a plain text file for the words spoken and load this also into the talk designer.
odeathoflife posted Fri, 22 February 2008 at 9:05 PM
and or if you deleted the character or reapplied the wva talk dfesigner will sometimes freak out, try restarting Poser 1st
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
arrow1 posted Sat, 23 February 2008 at 5:38 PM
Many thanks everyone for your advice.Cheers
