hamiltonpl opened this issue on Feb 24, 2008 · 12 posts
hamiltonpl posted Sun, 24 February 2008 at 2:45 PM
I have a VUE object that was originally a COB TrueSpace file. I am trying to convert this to OBJ, LWO, or 3DS so I can get it into Poser. I have it now in Vue 6 Esprit but prefer to do some updating in Poser.
Is there any shareware out there (cannot find anything so far) that will do the trick for me? tks
Windows 10 - Poser Pro 2012 - 64Bit - 24GB RAM - 4 x 3.40 GHZ processor
bruno021 posted Sun, 24 February 2008 at 2:58 PM
Nope. No way to convert vob to another format with Esprit. But I suppose that if you get the Vue Infinite PLE, you'll be able to export it to 3ds or obj. Bear in mind that some Vue objects are locked from export. Not a Vue limitation, but one put by the maker of the object.
hamiltonpl posted Sun, 24 February 2008 at 2:59 PM
Aaaarrrgggghhhhh!!!!!
bruno021 posted Sun, 24 February 2008 at 4:02 PM
Get the PLE, you never know.
Rutra posted Sun, 24 February 2008 at 4:33 PM
You can always send the VOB to someone with Infinite and ask him/her to do the conversion for you. It's a matter of seconds and I think this wouldn't be violating any law. I can do it for you, if you like.
hamiltonpl posted Sun, 24 February 2008 at 6:04 PM
Rutra - how do I get it the zip file to you? I would like an OBJ file from the conversion if possible. tks
hamiltonpl posted Sun, 24 February 2008 at 6:17 PM
I did download the PLE or so I thought - it creaed a file with no extension (inside the zip file) and I am unsure how to run it....ideas? Did the download not work?
MyCat posted Sun, 24 February 2008 at 9:57 PM
My PLE zip file contains a folder which in turn contains setup.exe and a bunch more folders and files. Unzip everything to a temporary folder and run the setup.exe, assuming you're on Windows.
bruno021 posted Mon, 25 February 2008 at 2:43 AM
Download it with Firefox, I could never get a proper download of the PLE wth IE.
thlayli2003 posted Mon, 25 February 2008 at 10:35 AM
Using the PLE to export OBJ works fine for me.
forester posted Mon, 25 February 2008 at 10:51 AM
If it was a Truespace file, and you have that Truespace file, I can get it into *.3ds or *.obj for you.
hamiltonpl posted Mon, 25 February 2008 at 9:55 PM
I have successfully imported it into PLE and am tyring to export it as an OBJ. My first attempt created the object but did not carry the material assignments - there are 55 separate material groups on this model. They look good in Vue but I need to keep these assignments so when they go into Poser I won't have to remap the entire obj for mats.
Thanks for all of your suggestions but now I need to save the file with mat assignments. Ideas?
