Imager opened this issue on Mar 11, 2008 · 13 posts
Imager posted Tue, 11 March 2008 at 12:56 PM
Hi, I've been using Photoshop for 6 years and I still don't know what a PNG file is for and/or what I do with it. Can someone help? Thanks! -Drew
ARTWITHIN posted Tue, 11 March 2008 at 1:10 PM
Attached Link: Wiki on PNG
To save time I have provided a link to Wikipedia's article on PNG. If that isn't sufficient for your needs, doing a Google search using he keyword PNG will call up so many sites with explanations that you should find what you want easily.
“Music is harmony, harmony is
perfection, perfection is our dream, and our dream is
heaven”
Henri Frederic Amiel
Lucie posted Tue, 11 March 2008 at 6:28 PM
PNG is just a file format, very similar to a psd really only it doesn't keep several layers in one document. Instead of offering psd when I create packs I offer them as png because the quality is the same only they don't seem to weigh as much as a psd would for some reason.
Imager posted Tue, 11 March 2008 at 8:04 PM
O.K., so I can load them and use them just like PSD files? Practically speaking, the sound the same as JPEGs.
bikermouse posted Tue, 11 March 2008 at 8:20 PM
My question would be: does it offer lossless compression or is it lossey like jpg?
ARTWITHIN posted Tue, 11 March 2008 at 8:46 PM
The first sentence in the Wiki article (link provided above): "Portable Network Graphics (PNG) is a bitmapped image format that employs lossless data compression.
There is more useful information and external links in the article.
heaven”
Lucie posted Tue, 11 March 2008 at 9:11 PM
Yes, you can use them like psd as long as the program you use supports transparency in png's, Photoshop started supporting it with version 6, not sure about psp, I know psp 9 supports it for sure, but I don't know about earlier versions... And no, it's definitely not like jpg, you can't preserve transparency with jpg which is something you can do with a png and you definitely don't loose quality like you do with a jpg.
bikermouse posted Wed, 12 March 2008 at 5:51 AM
I knew that but I wanted someone else to say it; a few years ago people were trying to find a replacement for jpg as there were copyright issues with the compression scheme also the lossy method of compression was unexceptable to some. png was seen as that replacement.
Angelouscuitry posted Wed, 12 March 2008 at 1:20 PM
.PNGs are very important to Poser users!
When you open a Poser Library all of the thumbnails are genreated by .PNG files.
Also once you've rendered a person if you want to export the render of the person, without the rest of the image(the Poser scene's background;) for composition here in Photoshop onto say an actual photograph, then .PNG is the only way to export an image with Transparent pixels(the Poser scene background at that point.)
bonestructure posted Sat, 15 March 2008 at 5:16 AM
PNGs were essentially developed to save images that would be the same size as JPEGs but wouldn't have the loss and artifacts common to JPEGs.
I have PSP 8 and it supports PNGs. I don't know about any earlier versions. I tend to use TIF files more than anything else these days, so I haven't really messed with PNGs much.
bikermouse posted Sat, 15 March 2008 at 12:54 PM
Tiff is a very versitile format - multible images in the same file etc. The biggest problems are limited compression and the fact that there are so many flavors of it; ps uses one corel another psp still another and macromedia another - everybodies got their own idea of how to set it up. (I learned all this when I developed a small utility for Bryce users called Tiffer a while back).
If you're working on your own have and have alot of drive space Tiff can be wonderful to work with - the problem comes in when you are working with others over limited resources.
Oils_on_Display posted Sun, 16 March 2008 at 2:40 PM
.:PNG is great for pretty compatible, high quality transparency. TIFF, as bikermouse stated, is cool if you have the correct software:.
Tanchelyn posted Sun, 16 March 2008 at 4:52 PM
PNG is also used for the creation of websites. It supports transparancy much better than gif, so you can, with the background image feature of Cascading Style Sheets layer several png images.
The downside is, as always, Internet Explorer. There are workarounds, but no real support.
There are no Borg. All
resistance is fertile.
