richardson opened this issue on Mar 13, 2008 ยท 7 posts
richardson posted Thu, 13 March 2008 at 3:32 PM
I'm having the usual problems getting a new install to work. I cannot seem to find all the "hidden" data logs that store info on your last install. ie, I cannot get rid of P7 completely. I know this because it stores my prefs. I think it's storing bad installation locations too (conflicts). I've tried to install on several drives to no avail. I remove the app. I then delete 2 Poser7 temp files in Documents and Settings/myname/.. Then the datalog(install failed). Finally the e frontier file .(.program files/efrontier). Yet,,, P7 still has info on my next install. Where is the other pesky BUGger? I need a "clean" install.
pjz99 posted Thu, 13 March 2008 at 3:39 PM
rofocale posted Thu, 13 March 2008 at 6:36 PM
Richardson,
go to start/ run and type in : regedit
There you will find the files shown above in the pic!
Good luck
richardson posted Thu, 13 March 2008 at 8:47 PM
Thanks! I have no report on the reinstall. Not sure what the problem is yet.
svdl posted Thu, 13 March 2008 at 10:10 PM
The Poser 7 settings files can be found in "C:Documents and Settings
You'll have to delete that folder and its contents as well before reinstalling Poser 7.
richardson posted Thu, 13 March 2008 at 10:11 PM
rofocale posted Fri, 14 March 2008 at 11:17 AM
Perhaps you should send a note to e frontier regarding this issue.
They might have a solution, who knows?!
