Forum: Vue
Subject: Is it possible to install Vue over itself?
BillyGoat opened this issue on Mar 13, 2008 ยท 2 posts
BillyGoat posted Thu, 13 March 2008 at 4:32 PM
Just curious - will I lose all my files?
My Poser import has gone south out of nowhere. I went to e-on and found that the you can replace the the ENV to get the Poser import running. It didn't work.
Any idea how to fix it?
Thanks
thefixer posted Fri, 14 March 2008 at 3:21 AM
I had to do a full install, not as bad as it sounds!
Assuming you have all your Vue files inside MyDocs then it is painless!
1 Place your e-on folder in a new folder called Temp or whatever, inside MyDocs.
2 Uninstall Vue from your pc.
3 Re-install Vue using it's normal parameters, i.e. MyDocs for files, Programs for system.
4 Delete the new install folder from MyDocs and replace it with the one you saved earlier in the Temp folder.
5 Job done!
this does work, I had to do it earlier when my Poser imports stopped, the pz3's would come in but weren't using any Poser shaders or textures even though I'd ticked the box!
I didn't lose anything with this method!
Injustice will be avenged.
Cofiwch Dryweryn.
