Subject: The Redeye Effect
ghoyle1 opened this issue on Mar 20, 2008 · 11 posts
ghoyle1 posted Thu, 20 March 2008 at 3:22 AM
No, I'm not trying to get rid of it in a photograph, I'm trying to create it in Poser 7. Any suggestions on how to create this effect in the Materials room?
Thanks,
Guy
vince3 posted Thu, 20 March 2008 at 4:58 AM
have you tried editing your texture map (copy) , so that you have a red colourized pupil area?
you could just add a circular red spot to your copy of the tex map and adjust the opacity slightly so that it is not a solid red, before merging layers.
if it is just a still image, then why not just add it in postwork?
lkendall posted Thu, 20 March 2008 at 7:41 AM
3/20/08
Do you mean a red pupil?
LMK
thundering1 posted Thu, 20 March 2008 at 9:13 AM
If you're going to do it in post, get a real photo (or take one) with bad red-eye and use that.
Can't get any more real than that.
Hope that helps-
-Lew ;-)
dadt posted Thu, 20 March 2008 at 9:28 AM
In the Material Room select the pupil then disconnect the Image Map node from the diffuse colour box and change the diffuse colour to red.
ghoyle1 posted Thu, 20 March 2008 at 3:54 PM
Thanks for the suggestions. I'm trying to do it all within Poser, not postwork, but I'm still playing around with the effect.
Guy
Miss Nancy posted Thu, 20 March 2008 at 4:35 PM
in humans, the pupil is the opening in the iris, hence it's just an empty space surrounded
by a circular muscle.  the red-eye fx is the flash illuminating the human retina.  but then,
I reckon poser figures must have a black pupil that's opaque, otherwise we'd see default
renders with both nostril glow and "retina glow" 🤣
thundering1 posted Thu, 20 March 2008 at 4:49 PM
Miss Nancy - your avatar has grown!
Exactly - it also has different hues - not just a blank red dot which will look cartoonish. I'm afraid that if it is made a "material" how much gets lighted/you will see will depend entirely on the lighting (unless the Materials Lab has a Luminance Channel - I'm blanking).
The closer a flash is to the lens, the more reflection you will get from the retina - which is why we only see it through the pupil.
I'm still thinking your best bet is postwork if you want it to look real - and years of family and friends' photos would be an almost endless supply.
bagginsbill posted Thu, 20 March 2008 at 5:39 PM
Try this thread:
Cat's Eye Glow in Animation
The issue there was a cat's eye (green) not human, but the principle is the same.
I then tried it in an animation - the Poser cat's eye is not shaped great for this, but you get the point. It might work on your figure. Be aware that many figures have a cornea bulge morph. You may need to use that to improve the results.
Click here for the animation
thundering1 posted Thu, 20 March 2008 at 6:04 PM
That's funky!
ghoyle1 posted Fri, 21 March 2008 at 2:35 AM
This is pretty close to what I'm looking for. Thanks for the heads-up, Bagginsbill!
Guy
