Subject: Is there a way to make lights from a prop?
Eagle_hawke opened this issue on Mar 23, 2008 · 6 posts
Eagle_hawke posted Sun, 23 March 2008 at 10:10 PM
Hey all,
        I'm trying to create a light prop that actually illuminates the enviroment. For example, If I take a simple cylinder prop, is there a way to use the material room or lighting effects to make it glow in the dark? I know this can be done in Studio Max. But I want to know if this can be done in Poser as well.
                               Thanks for any help.
pjz99 posted Sun, 23 March 2008 at 10:21 PM
I have a sample poser prop in my freebies, a lamp with a light set that is intended to be parented to the prop and act like a practical light.  You're welcome to check that out.  It is a bit of a cheat, although I think the concept works pretty well and I use it a lot now.
My Freebies
svdl posted Sun, 23 March 2008 at 10:23 PM
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2217752
It can be done.
My gallery   My freestuff
pjz99 posted Sun, 23 March 2008 at 10:28 PM
Yeah that is a powerful cool trick, although I think it's a bit overkill for just faking a lamp with no object directly next to it to catch a realistic looking glow (what the gather node does in that thread).
My Freebies
svdl posted Sun, 23 March 2008 at 10:41 PM
That's right. If the lamp is free standing, just using translucence and a spot or point light inside the lamp is enough.
Eagle_hawke posted Sun, 23 March 2008 at 11:45 PM
That Ambient is exctly what I'm looking for thanks! I've tried using the lights parented to translucent objects but I don't care much for the end results.Thanks though for the suggestion.
