Subject: Wasn't there a Library button UI hack?
Gareee opened this issue on Mar 26, 2008 · 6 posts
Gareee posted Wed, 26 March 2008 at 8:12 PM
To make the library buttons smaller? I seem to recall something from the dim past about it..
pjz99 posted Wed, 26 March 2008 at 8:26 PM
Have not tried it but it appears to be RuntimeuilibraryPalette.xml
It seems likely you can change icon size there with Left/Top/Bottom or some such.
My Freebies
layingback posted Wed, 26 March 2008 at 10:32 PM
There was for Poser 5 (it was easier to find and read on PoserPros until recently, but it is here if you search far enough back - posted under my nick).  But unfortunately it won't work in P6.  As eF actually retrograded that piece of code (from dynamic to hard coded) you can only guess at the reason.
Probably to shave a few minutes off the time to code the multi-column library option introduced around that time.
BTW, you can still use it to EXPAND the size of the library entries - but you probably didn't want to do that.  ;-)
(OT:  Wonderful!  Firefox on Linux will actually let you use its spell checker on this fckeditor :-) )
PS:  The ParamDials hack to reduce the height of the entry for each dial still works - on P6 at least, don't have P7 to test but I suspect it still will.  It removes the image of the dial, and lets to stroke across (or up/down) the dial name instead.
Netherworks posted Thu, 27 March 2008 at 12:18 AM
The ParamDials hack does work on Poser 7.  I even moved the "value" column over a bit after playing a bit with the xml.  Gave me more room for the dial names. :)
Gareee posted Thu, 27 March 2008 at 1:00 AM
Yeah that dial hack is what made me remember the library hack, but if it's hard coded now, guess there's no way to reduce them. I'll have to send in a bug ticket for that.
On my 28" monitor, that library palette is much larger then it needs to be. (I'm talking about the main library buttons on the far right.)
They could easily still look good, but be 1/4 the current sizes.
Netherworks posted Thu, 27 March 2008 at 1:20 AM
Yeah, I'd LOVE to see a way to reduce those massive folder icons.
