Subject: SLI Mode Win64 bits..anyone?Nvidia8800GTS..anyone? Huge Problems!
softcris opened this issue on Mar 30, 2008 · 38 posts
softcris posted Sun, 30 March 2008 at 3:03 AM
Hi there...after my big disapointment  finding out that my 'dirt' 8800GTS ..'s...(2 of it) could not handle my TWO monitors (can't live anymore in small space to work in).. I went to a 'bread&water' diet and finally brought to my (enormous surprise..2 dare it) self a Samsung 275T - because was the best reviews in a ok size...and also because I could not buy an EIZO same size ;(
After 3 months finally I'm using the SLI Mode and all is odd!
So it's right here and I've spend about 6 hours trying to set it up and make it work. Yes I'm in it..but no Poser not Vue (64bits)..CS has complaint about the 'Natural Color Pro' (soft include to make it colors right) Even Nvidia's Control Panel is not very 'happy' the 3D tab shows as lots of pixels in  chaos.
Had to reboot the computer about 30 times and try all POSSIBLE interchange between the two cables plus one from my 'old' flat monitor (case I change to Non Sli mode, which I will eventually and change back again...
so here it's.
a 2 cards having 4 HDMI contacts.
Samsung comes with 1 HDMi( DVI- HDCP)  and 1 VGA (RGB) .
I'm using 1 HDMi( DVI- HDCP) For the moment! in SLI Mode.
Ok.
Unfotunelly - trying to make it right I probably made it wrong.
'Now I'm in DIGITAL mode (which I understand is the HDMI funtioning)
Takes eternity for starts Win...does not anything but black screen..
My Device Manager SHOWS 2 monitors!   guess..2 graphics cards..
2 SyncMaster 275T Digital.
Poser does not starts right, can't see what I'm doing...because the windows are overllaping each other in it..even if I try does not shows right - but renders - and shows the render!
Vue 6 also the same (the one I got is PLE and 64 bits) Photoshop is stable but some functions like my brushes 4ex. shows only when I'm in brushes not when I'm in eraser or other.ODD!
Anyone here can tell me what should I do?
Obvious these are not correct and it seems to be the cause of the problems.
Went to NVIDIA to see if any clue I could find there - none! Only BETA drivers etc...
The driver I'm afraid to unistal and then loose contact totally w/ the screen now showing again.
Please? Thanks.
Cris
"'you shut up!  or I'll bring democracy to your country! "
Cris Galvão aka Softcris  - www.crisgalvao.com
(or softcris, SoftCris)
Rendering since 1997 and
at Renderosity since 1999.
OS Win 8.1     64 bit
