Subject: question about grouping tool
smalll opened this issue on Apr 07, 2008 · 6 posts
smalll posted Mon, 07 April 2008 at 2:57 AM
Hi, everyone.
I pray aid of you.
I want to make pupil of the eye.
I used Aiko 3.
And It was used Cartoon w / Line
I like cartoon mode.
My purpose is like next.
I can color like next in advance.
But pupil is not colored.
So, I clicked Grouping tool.
And select leftEye.
And click New Group.
And I named it 'pupil'.
And next.
The next is problem.
I can't select anywhere.
Why?
How can I make new Assing Material pupil of Aiko 3?
Can you help me?
Please....
wimvdb posted Mon, 07 April 2008 at 6:33 AM
Move the camera away from the eye, then you will be able to select the polygons
If you are too close, you cannot select them
smalll posted Mon, 07 April 2008 at 8:39 AM
Well really!
It's pretty amazing.
Thank you very much!
lesbentley posted Mon, 07 April 2008 at 9:07 AM
You may not need to create a new group. Try this. Select the eye. From the Display style pallet drop down menu, select "Element Style". Choose "Smooth Shaded". If desired set the 'Specular_Value' to zero, and change the colour of the Iris material. Of course the eye is no longer in true cartoon style, but you may think it looks OK.
The above example uses V3, but I think Aiko3 works the same.
smalll posted Mon, 07 April 2008 at 9:42 AM
Thanks lesbentley.
I did not know like that way.
It is amazing.
And I tryed it.
It is like next image.
But It can not Render.
scott8539 posted Tue, 08 April 2008 at 3:52 PM
Attached Link: toon shader
try the toon shaders in freestuff so you can render normaly.
